Removing fuel gauge (or any of the smaller gauges) on a series 3 .. help?
According to the Haynes workshop manual the fuel gauge can be removed by first removing the speedometer, and then through the hole left by the speedo you are supposedly able to release the retention clamp which all of the smaller gauges have holding them in.
Problem with this is, I just don't see how.. I can barely get my hand in there let alone a pair of pliers, and the knurled nut which needs to be unscrewed is tight as all hell.
Any ideas?
Any ideas?
jedw84 (08-04-2018)
no metal tools in there! spray WD40 ON THE KNURLED nuts using the thin red tube that comes with the can. You can wrap a bit of duct tape over the nut if too tight to give you torque.
the hole is big enough for a gorilla-sized hand like mine, so unless you are Godzilla, it should fit.
AND disconnect the battery FIRST unless you like the smell of fried wires.
The following 2 users liked this post by Jose:
jedw84 (08-04-2018),
Roger Mabry (08-03-2018)
Received 2,399 Likes
Since it does this reglarless of whether the right or left hand tank is selected, I figured it is more likely the gauge that is bad and not the 2 seperate sensors in the tanks. I could be completely wrong.
Received 10,748 Likes
Easy-ish test:
Remove one of the rear tail light assemblies (either side) (10 minutes max) to reveal the wiring to the fuel tank sender wiring. Disconnect the light green wire and, with the key "on", touch the light green wire to ground. If the gauges moves to "Full", then the gauge is OK. If not, the gauge is faulty or you have a wiring/connection problem from the sending unit to the gauge
asleach2889
03-13-2016 09:07 PM
mbalce
07-16-2015 11:42 PM
Cerberus
11-04-2008 06:22 PM
