rob xj6 series 1
Hi everyone
I have a problem with my series 1 -73 jag just recently I have been working on fixing up my brake callipers and ball joints and I've must have over worked my bonnet release lever because now only one side opens up at closer inspection one cable has pulled thru from the bonnet catch. does anyone know how to release the catch from inside the bonnet area? and can someone send me a photo on the passenger side catch so I can see how the cable enters the catch and which way I need the push or pull the catch for it to release my bonnet thanks rob |
3 Attachment(s)
If you look at the pics you can see I have marked where you need to hook a coat hanger or piece of wire around the catch and pull it towards the windscreen.
You will have to lift the right side of the bonnet and jamb it with a wood block. Keep in mind you will be going in over top of the battery so wrap your wire with insulation tape so you don't short out the terminals to the body or bonnet. Good luck, maybe someone else has a better way to do this. :icon_beerchug: Attachment 94934Attachment 94935Attachment 94936 |
There is a way in via the wheelarch for just this eventuality
(Post 1050629)
rob's bonnet catch problem
thanks guys
I going to try drilling a hole in the wheel arch to see if I can access the bonnet catch from there it was some thing I was thinking about doing, so I'm going to give it a try I think it will cause less damage to my paint job this way i'll kept you posted |
Do you want some measurements so you don't drill through something you shouldn't
rob bonnet
yes that would be great
I think some of the bolts that hold the catch down can be located in the wheel arch? I need to have a look and relate it back to your photos see how you go with the measurements not sure where to measure from rob |
Here you go
5 Attachment(s)
It looks like my car has had the same proceedure.
I have 2 holes in the gaurd, both work,just tried them. Hole 1. is near the 2 bolts for the catch, the hole is forward of the front bolt and slightly to the left(if yo are looking toward the front of the car). In the first pic you can see a tab above the hole near my finger,that tab needs to push towards the rear of the car. A short screwdriver will reach(1-2 inches inside the hole).....update, hole 1 looks like it might have alredy been there, hole 2 has been punched through. Attachment 95149Attachment 95150 Hole 2. is near the front of the battery tray,in the third pic it is near the rear of the inner gaurd(about 240mm in from the wheel arch. You will need a screwdriver about 200mm long to reach this one.(from base if handle to tip). latch needs to be levered towards the rear of the car also Attachment 95151Attachment 95152Attachment 95153 Hope this helps:icon_toast: When you post a thread,make the title what the problem is so you get a lot more answers and faster. |
Easy option
(Post 1050629)
:icon_toast: |
robs bonnet problem fixed
I had a look today under my wheel arch and found a rubber plug
I pulled it out and stuck a screw driver in it and wiggled it about and pop the bonnet opened straight away what a relief ! thanks to everyone |
Hi Rob,
A couple of books here you might be interested in. The $50 one will be the best money you ever spent. I got one for $80 ,and is one of the best workshop manuals I have owned. If you are interested I can buy them and post to you for cost. Jaguar XJ6 service manual | Other Parts & Accessories | Gumtree Australia Gold Coast North - Norwell | 1059791824 jaguar xj 6 parts catalogue | Other Parts & Accessories | Gumtree Australia Caboolture Area - Deception Bay | 1059800508 |
