RPM drop to zero
Old Oct 24, 2014 | 08:22 PM
ottotto's Avatar
Default RPM drop to zero
Hi,
got my 1974 XJ12 a few weeks ago and the engine was working fine so far. Today I started cold and had it run for a few minutes. After warming up all of a sudden the RPM dropped to zero. Restarted a few times and the RPM went up to about 2000 RPm and dropped again to zero, without any stuttering or similar.
To be clear: the engine stops running, so it's not only the RPM gauge is dropping to zero.
Any idea what that might be? Probably no fuel supply?
Would be great if someone had a similar problem and got it fixed.
Eric
Old Oct 25, 2014 | 07:31 PM
icsamerica's Avatar
Lets start with a fuel pressure guage. If you dont have one then pick one up at your local autozone and post the fuel pressure.
Old Oct 26, 2014 | 09:40 AM
ottotto's Avatar
Thanks, will try today and let you know if it cured my problem.
Eric
Old Oct 26, 2014 | 10:28 AM
JagCad's Avatar
It would be odd indeed if the engine stopped running and the tach displayed numbers!!
But, as the tach relies on ignition pulses, it is a very good clue. Ignition issue!!!
Whatever device is making and breaking isn't doing it. Points and condensor or electronic.
Carl
Old Oct 27, 2014 | 08:49 AM
ottotto's Avatar
Carl
Hi,
The former owner seemed to battle cables and wiring and I think focusing on wiring and the ignition part is also necessary. Wanted to avoid this part for later on but since there is no problem with fuel pressure the ignition might be the issue.
Dave1109971
Dec 15, 2015 06:16 PM
tomkilner
Oct 9, 2015 07:10 AM
inactualis
Oct 2, 2015 11:13 AM
baskervillema
Oct 1, 2015 06:43 PM
