Jaguar Forums - Jaguar Enthusiasts Forum (https://www.jaguarforums.com/forum/)
-   XJ6 & XJ12 Series I, II & III (https://www.jaguarforums.com/forum/xj6-xj12-series-i-ii-iii-16/)
-   -   RTV and transmission pan cork gasket (https://www.jaguarforums.com/forum/xj6-xj12-series-i-ii-iii-16/rtv-transmission-pan-cork-gasket-207240/)
yachtmanbuttson Aug 27, 2018 07:54 AM
I guess I thought RTV can be used anywhere and was a miracle gasket cement - not so. My cork gasket is leaking like a sieve. In all your experience what's the best approach for the transmission cork gasket?
Doug Aug 27, 2018 08:06 AM
My approach is to toss cork gaskets in the trash and use a different material. But, alternatives might be hard to find for the old BW boxes. Worth some shopping around, though. What trans do you have? BW65? BW Model 8? Model 12? Some of the old BW transmissions were used in other cars, which opens up some shopping options.
For example (and as I recall), the Model 12 is virtually the same as the Ford "FMX"....used in a couple million 60s-70s Ford products.
Doug Aug 27, 2018 08:09 AM
And, regardless of gasket material, make sure the transmission pan is in good shape. Specifically the gasket mating surface. Sometimes they're distorted around the holes and need a bit of hammer work to become flat again
yachtmanbuttson Aug 27, 2018 08:28 AM
It's a BW65. And I did hammer out the mating surface of the pan. I've seen other site recommend Permatex #2 for cork?
JagCad Aug 27, 2018 09:59 AM
True, there are better gasket materials than cork.
1. If you can't find one, better material might be available in sheet form. Cut out your own.
2. Cork can work, but, needs some help.
Apply the sealer only to the pan. Let it set. Install the bolts to finger tight. Snug to foinal torque in a criss cross pattern. Do Not over tighten. It merel deforms the cork assuring a leak.
Cark
yachtmanbuttson Aug 31, 2018 08:32 AM
Just found a plate on the side of my transmission that says it's a BW66 SN#608050826. I thought that the BW66's didn't make it into the Jaguars until 1980 and mine is a 1975. I know my engine is not a numbers matching so I might assume that the transmission was swapped out by the PO also. And if it's not the original transmission it might explain my speedometer and odometer reading high by 20% or so.
JagCad Aug 31, 2018 10:33 AM
Yacht:
Seems as there was a swap by the PO!
As to the speedo. indeed, The match of driver gear in the box to the driven in the speedo head governs. And that ratio related to the ratio if the driver vs driven gear in the differential.
If it bothers you and you seek a fix, open another thread and I and others more qualified will seek a fix.
My electronic speedo suffers that way. I can fix it. But never got around to it, and at this stage, not likely.
Carl.
© 2026 MH Sub I, LLC dba Internet Brands
