rubber seal for fuel filler cap
Old 04-04-2017, 06:20 PM
aquatiteman's Avatar
Default rubber seal for fuel filler cap
Hi everyone...I am looking for some advise as to how I replace the rubber seals seals in the fuel cap filler for my XJ6...any help advise would be greatly received....thanks
Old 04-05-2017, 08:47 AM
Doug's Avatar
Received 10,740 Likes on 7,096 Posts
Don't what model you have but on a Series III the cap seals are retained by little 'starlock washers'....which can be gentle wiggled off and re-used. Wriggle the starloks off, remove seal, install new seal, push the little starlock washers back into place. That's it!
Look at item #11 in the illustration..
https://www.jaguarclassicparts.com/u...r-cap-and-lock
Earlier XJ6s might be different, I dunno.
sov211 (04-03-2023)
Old 04-05-2017, 02:32 PM
INDYJAG-84's Avatar
I just replaced mine on a series 1 last weekend. Like Doug said, pry off top two star retainers (reuse). Pull old rubber gasket out (its sandwiched in groove). I found the new gaskets a bit fat and didn't want to go back in groove so I used a flathead screwdriver and slightly opened up the groove. I then applied a little silicone lubricant to aid in sliding new gasket back in between metal groove. Once in I just taped the metal back down although not necessary. I re-applied star retainers using appropriate sized nut driver to shove back on stud.
Old 04-05-2017, 03:50 PM
Thank you guy's very much appreciated. I wish I had found this site a few years ago when I started on this project. A great source of information. Cheers
Old 04-06-2017, 09:11 AM
JagCad's Avatar
Received 2,399 Likes on 1,880 Posts
Hmmm, the seal kit I've had on hold is a fibrous pad. Matches the sad looking ones on the caps on my 83. How they pass the vacuum test part of SMOG is a question best left sans an answer.
CAVEAT. Put a catch cloth across the open tank filler and under the caps to be worked on.
Carl
LT1 jaguar (04-03-2023)
Old 04-06-2017, 04:04 PM
That's good advise...thank you Gents
Old 04-02-2023, 10:09 PM
xjpanther's Avatar
Where did you get the new gaskets from?
Old 04-02-2023, 11:18 PM
Doug's Avatar
Google "Jaguar AEU1576" and "Jaguar AEU4174"
They're out there; silly expensive.
I bought some sheet neoprene and made my own
The following 4 users liked this post by Doug:
LnrB (04-03-2023), LT1 jaguar (04-03-2023), xjpanther (04-02-2023), yachtmanbuttson (04-03-2023)
Old 04-02-2023, 11:37 PM
xjpanther's Avatar
Thanks for the response. I have a series II but that’s good to know for future reference. Fortunately, I found the part I needed and ordered it from Moss.
