Series III - which Trani fluid to use?
I'm finding conflicting info about which trani fluid to use for my 83' xj6. The posting here says he uses Dexron III/Mercon
https://www.jaguarforums.com/m_22426/tm.htm However, AutoZone told me that the BW66 calls for Type F trani fluid (according to their computer). I have not yet changed the fluid and filter yet, but would like anyone's input on the following: 1- which fluid do i use? 2- does anyone use/recommend using Lucas trani additive? 3- apart from dropping the trani pan, do i need to flush out any fluid still in the trani? if so, how do i do this? Appreciate all your help! thanks, cal |
RE: Series III - which Trani fluid to use?
I can say yes to both. The original fluid was type F which is completely compatible with Dexron III.
