Jaguar Forums - Jaguar Enthusiasts Forum (https://www.jaguarforums.com/forum/)
-   XJ6 & XJ12 Series I, II & III (https://www.jaguarforums.com/forum/xj6-xj12-series-i-ii-iii-16/)
-   -   side moulding 1987 xj6 (https://www.jaguarforums.com/forum/xj6-xj12-series-i-ii-iii-16/side-moulding-1987-xj6-128576/)
dansxj6 10-12-2014 12:13 PM
Can anyone tell me best way to remove side moulding on s3 xj6?
Daniel
Doug 10-12-2014 12:36 PM
If it is the stick-on type then a heat gun will ease the peeling-off process.
If it's the rivet-on type, well, you'll have to drill the rivets.
dansxj6 10-12-2014 12:54 PM
So they did it both ways, no standardization?
dansxj6 10-12-2014 01:00 PM
Doug 10-12-2014 01:04 PM
None of the Ser IIIs came with factory installed side mouldings. They were all installed after the fact, usually by dealers using local suppliers/installers. So, no, no standard type.
Jose 10-12-2014 03:48 PM
I've yet to see a Series 3 XJ-6 or 12 with the stick on side moldings, all I have seen are the rivetted ones which were for the USA only.
Fraser Mitchell 10-12-2014 04:47 PM
Mine had them, and very useful they were too, stopping a lot of dings in supermarket car parks. They were black and lined up with the black bumpers front-rear, so looked the part. They were glued-on. As Doug says, use a hair dryer or not-too-hot hot air gun. You can also use dental tape as a way of cutting the glue whilst pulling gently. It needs two of you, of course, to do this.
