small gauges
Old May 31, 2014 | 07:25 PM
wardhill's Avatar
Default small gauges
Hi all How do you release and replace the light bulb in the smaller gauges. can't find anything in search or manuals. I have the dash out on my dining room table
thanks
Jeff
Old May 31, 2014 | 07:33 PM
Doug's Avatar
On the small gauges I recall the sockets being a friction fit into the holes and just need a bit of wriggling to remove them.
Old Jun 1, 2014 | 07:06 AM
wardhill's Avatar
thanks
that's what it was
Next is how to remove the bulb from the tach. looks sealed
anyone?
Old Jun 1, 2014 | 07:20 AM
Doug's Avatar
Yeah, I recall that the tach and speedo have different bulbs and sockets than the small gauges....can't remember if there's any trick to remving them though. Maybe they're the type you twist 45º to disengage?
Not sure what you mean by 'sealed'.
All the bulbs come out of the gauges one way or the other.
Old Jun 2, 2014 | 11:04 AM
wardhill's Avatar
figured it out
tach bulb is a screw/threaded type. the housing is a multi pronged fitting that you pry or twist out of the tach base
X308XJR
May 20, 2019 06:50 PM
vwbusbits
Oct 13, 2015 03:43 AM
Dave1109971
Oct 2, 2015 06:11 PM
3lvis
Oct 1, 2015 01:56 PM
