stop light switch for 1987 XJ6
The stop light switch on my 1987 XJ6 seems to have stuck in the on position and burned itself out. Is there a good way to test it> I have it off the car. If it is ruined, where should I get a replacement? And, should the brake lights come on if the ignition switch is not turned on. I am used to cars where if you push on the brake pedal, the brake lamps come on.
Thanks for the information, Neal Lewis |
RE: stop light switch for 1987 XJ6
WNLEWIS Here is the source that I will be using
http://www.autopartswarehouse.com/se...=2001%20Jaguar shw57 |
I didn't see the correct application for your year model in your link. I have it here:
http://www.motorcarsltd.com/item.wws?sku=IN101859 |
