Stripping alloy wheels?????????
1 Attachment(s)
Scored a set of XJS Starfish mags to through on my XJ6.
They are pretty grubby & will either need stripping & polishing or maybe re-painting. Either way they will need to be stripped. Anyone have an "easy" way to do it? |
Originally Posted by Rickxj6
(Post 1494755)
I haven't. I've stripped a set of Starfish and Lattice wheels...and started doing on a set of Pepperpots but gave up. Very hard work and quite time consuming in all cases. The original finish is very very robust...at least in terms of adhesion. I couldn't find any over-the-counter products that worked very well or very fast. I would consider having the wheels professionally stripped or sand blasted if you can afford it. Others will chime in Cheers DD |
I am just curious if a known enemy of painted surfaces might be recruited. Brake fluid.
Or, I've read of aircraft stripping compounds. Paint over alloy in each case. All aircraft stuff not cheap, though. Carl |
Originally Posted by JagCad
(Post 1494862)
Or, I've read of aircraft stripping compounds. Paint over alloy in each case. All aircraft stuff not cheap, though. Carl No rush to do it but when i do i don't want it to take forever. |
soda blasting.. Buy a do it yourself small unit - clean / blast the wheels and then sell the equipment ,..or rent one, and do the wheels.
The wheel surfaces are very durable because of the environment they have to live in. There is no magic solution you can find at home that will work. google the term "soda blasting wheels.." |
1 Attachment(s)
Well i got the wheels pretty much how i want them. Gave them a reeeeeeally good clean & soften up with thinners & then painted them with Duplicolor metalcast "smoke". The car is almost just how i want it.
Looking good Rick, hoping to see it soon.
Not exactly my taste, but, absolutely a definite repurpose of an older wheel in to today.
It could grow on me, though, and fast.... Paint can do so much.... Way back when my son acquired a little Four "Mazda" Courier truck. The PO spent a lot of money lumping it with a "hot" 289 SBF. messed it and the rear end up. sold cheap!! Son replaced the 'overwhelmed" rear axle assembly with one from a contempory Mustang. Too wide. Ingenuity fixed that. The long side cut down and two short side axles used. Perfect. Big wheels fit within the openings. Older alloy wheels resprayed in Gold and black. Yellow original paint shined up good. A bit of black pin striping and it was contemporary yet different. Carl |
