tweaking idle - slight heistation
hi all - i've been fix some things on my car and now have a slight idle issue when the car is in drive with the brake pedal pushed...it is all started after a fixed my vacum leaks...so the car idle's fine, but when i am at a red light and start to hit the gas it heistates a little bit before she gets moving...it doesn't come close to stalling out, just the RPMs drop a bit, and it is very noticable...any ideas what adjustment i can make to compensate for this?
Check the accordion hose and the smooth rubber hose that attach after the air flow meter and to the throttle body for leaks. I had free air coming in there that caused much the same thing. On the accordion hose, look down in each crevice.
actually that was one of the areas i fixed...although it is pretty rotted out and i ordered a new one from jagbits...i also have more info, the issue goes away when the car is warm, so i am pretty sure it is the temp sensor that is telling the car it is warmed up when it is not...does that make sense?
Originally Posted by pdog2000
(Post 410437)
Yes, it does....it would cause a lean condition....sorta like an older car where the choke wasn't working right Cheers DD |
