valve adjustment question
I got the bucket polished on my stiff tappet and got it to slide easily, now im back to checking my clearances again, still got just the one excessive one, .018, book calls for .012- .014, existing shim is a v so being as shims go up a letter for every .001 i will need a z just to get it to top of the tolerance range correct? is there anything past z? i dont think the shims are stackable..
Also, there's quite a bit of upper cam bearing wear, to the point of the center being a totally diff colour. will that be enough to cause an excessive valve clearance?, i thought about swapping top and bottom bearings around and rechecking but my back is aching for now!!!
Darren
Darren
I have located a tappet that is .015 thicker than standard, that being the case, what size shim would i need? its hard to find the sizes of the shims!
keep in mind i have a v shim now and .018 clearance. I would like to see it at .013. Also a vendor to buy just the shims i need would be good too!
I'd talk to the guys at Coventry West....Dick Maury if possible. They do tons of Jag cylinder head work. I reckon they can fix you up with whatever you need
The shims do wear where they are in contact with the valve head, and one trick, if you can't get a new one, is to turn them round so the wear side is against the tappet. I once got a really rattly tappet, and it was a bent valve due to it being a bit lazy coming back up after the engine had stood a while, so the piston kissed it.
The shims come in all sizes. We do not use the letters as most are worn off and the replacement shims do not use them. If your cam bearings are worn, they need replacement before you can accurately measure clearance. Check your clearance, mic the shim you have and do the math to determine which size shim you need. You do not mention which size you currently are using so no idea which size you need. Not sure where you found a thicker tappet. Most tappets are stock or machined undersize. We stock a wide variety of shims and can custom cut sizes if needed.
Here is the link to the oversized tappets i found.
83 1983 Jaguar XJ6 Cam Follower - Engine Mechanical - Original Equipment - PartsGeek im guessing these are a bad idea!
Darren
when i get home i will mic the existing v shim and see what it is, but until then, do you guys have the cam bearings? i did a search on your site but it said no matches found.
Darren
Darren
i have plastigage, but im low on it, so i will use whats left when new bearings are installed, i am in this far, no point in messing about, new bearings should increase oil pressure a wee bit too!, then i can measure and order the new shim i need!!, get motor running quietly then back to chasing the damned machine gun sound! im convinced its the flex plate, however i cannot seem to find any loose rivets!!! of course now that cam is out i cannot rotate engine, but i can fix my power steering leak!!! all this while remodeling a condo as a side job and redoing my daughters room too!! im plum wore out!!!
Thanks!
Makes my bewilderment with tasks look simple!!!
Back under the Jag later to finish the starter install. More complex than expected. but, I seem to do things the hard way always!!
A fence section to fix amongst other things.
Carl
Carl
I done went and got sick!!!! i am now well enough to be understood on teh phone so i have ordered my cam bearings and hopefully i am well enough to install and measure valve clearances when they show up!!! wish me luck!!
Oil pressure is good still!
Richard_gib
Sep 12, 2015 07:08 PM
