Wet AED
Wet AED
Hi all, I’m getting very poor mileage on my series 2, I think the carbys are HIF and it has the automatic enrichment device still fitted. I can visiable see fuel weeping from the device once the car is up to temp and there is always a strong smell of gas. I was wanting to see if blocking off the device all together would fix the problem. Simple as clamping a bolt into the inlet tube? This will cut the supply. Anything else to do?
cheers
Scotty.
cheers
Scotty.
These devices go back decades to the 60s, and a favourite trick of the time was to install a switch so the thing could be turned off before the thermostat did the job, It saved on fuel a bit. Of course you can still buy these things, and kits to put in new seals too.
AED Gasket Kit - SU Carburetters
AED Repair Kit - SU Carburetters
A.E.D Unit - SU Carburetters
Last weekend I totally removed the AED, blocked all of the ports. She was a bit hard to start but with a few minutes of feathering the gas pedal she warmed up and ran well. I adjusted the carbs, they were set extremely lean, I guess to compensate for the extra fuel from the AED. It responded well to the adjustments, once warm she started perfectly, ran way better than before and it’s gone from 11mpg to 20mpg. Happy boy! At some stage I’ll convert to the manual conversion.
Received 3,804 Likes
Received 8,933 Likes
