what expansion tank brand I have to choose ?
so it's time for a new expansion coolant tank.
Which one to choose ?
On Ebay there is a MTC one. Without bolts.
is this one good? will my bolts fit without problems ?
Should I also replace the hoses seals ?
and last question: any procedure on how to replace it (DIY) ?
thanks
thanks
Received 10,757 Likes
I've never had to buy one so I can't comment.
thanks
thanks
https://www.jaguarclassicparts.com/u...-from-v-200747
Partially drain cooling system, disconnect hoses, unplug the coolant level sensor, remove bolts.
Might needs new hoses...almost certainly if you're still on the originals
The_Sauce
05-19-2010 11:33 AM
