where is reverse lamp switch 1986 XJ6 automatic
Old Mar 16, 2018 | 02:36 PM
0811's Avatar
Default where is reverse lamp switch 1986 XJ6 automatic
Reverse lamps are not lighting when car put in reverse
Old Mar 16, 2018 | 03:06 PM
Jose's Avatar
should be in the driver's side of transmission. Download the Service Manual from the https://www.jaguarforums.com/forum/x...ck-links-5913/
Old Mar 16, 2018 | 06:30 PM
alynmurray's Avatar
Make sure you have 12V+ to switch on side of trans and 12V+ from switch to lights then check the grounds... Make sure switch is in good working order - not loose or damaged.
Old Mar 16, 2018 | 06:38 PM
Nanonevol's Avatar
From a search of forum, Motorcarman says:
Switch is on left side of transmission.
"2 wires are for the P/N start inhibitor and the other 2 are for the reverse lamps.
The P/N wires will 'make contact' in 2 places (Park and Neutral) and the other 2 wires will be closed circuit in only one position (Reverse)."
While performing my state inspection I was told my reverse lights worked but were "flaky".
Old Mar 16, 2018 | 07:05 PM
Doug's Avatar
More:
Adjusting Backup Lamp Switch, Series III XJ6
It should be noted that not all the switches were slotted for adjustment. If not, the mount hole can be enlarged
Old Mar 17, 2018 | 07:55 AM
alynmurray's Avatar
Default reverse light switch
Have the reverse lights ever worked properly? If so, I would not be
adjusting / moving the switch,.. as it is probably set correctly. instead I would be testing the circuit for continuity first. Simple system - easy to trouble shoot with a cheap test light.
Old Mar 17, 2018 | 11:12 AM
JagCad's Avatar
Yup.
And, as I recall, they are only "lit" with the ignition switch on. I'm sensitive to switch sourced volts.
On lumping, that switch or a similar one went to the shift tower ala XJS.
Alas, mine went "bonkers". Reverse lamps always on!!! For now, I removed the bulbs. In the spring, I'll open the console and address the switch on the shift tower. Durn, I had a new one. it left along with the original tower to a needed lister. so, I hoe it is merely an adjustment thing.
I'm good at opening the console cavity....
Carl
Don B
General Tech Help
17
Aug 8, 2017 09:11 AM
Don B
General Tech Help
Nov 9, 2015 12:59 PM
Jun 21, 2012 04:31 AM
Exterior
Dec 12, 2005 05:29 PM
Dec 8, 2005 02:52 PM
