Wiring Question
1 Attachment(s)
Just took my dash apart on my 1983 XJ6 to replace it with a newer one. When trying to put it back together, I can't remember where the two wires in the attached pictures go. Can someone please advise? Thanks!
A little hard to tell but those might be fibre optic cables that snap into sickets behind the ignition switch and headlight switch
Cheers DD |
1 Attachment(s)
Thanks Doug. I attached a better picture (hopefully). As you can see, the two black wires are being fed from the same location from behind the center console. I looked behind the ignition and headlight switch and couldn't find where they would connect to.
