XJ6 S3 Adjusting idle - How the hell?!!
Hello all!
So i am holed up with a cold in bed but been thinking about adjusting the idle. Prior to getting a cold i had adjusted the butterfly which went swell. Could you please tell / show me how the hell I am meant to get my Hex into that blasted hole???!!! How have you guys hacked the hex key to fit? I just cant get to it. No matter what i do. I would appreciated any pics and advice!!! Thank you! |
Some do cut off an allen key to suit, yes
I use a allen socket. I can just wiggle it into place and turn it with my thumb and forefinger. If the screw is very hard to turn (they often are) it's probably gummed-up underneath.....and the air passage is likely gummed-up as well. The fix here is to remove the air distribution block and clean things up. Order a new gasket first. On removal you'll see the 'over run valve'....which looks like a spring. Pay close attention to how it is installed so you don't reinstall it backwards https://cimg0.ibsrv.net/gimg/www.jag...2a0537f686.jpg Cheers DD |
Originally Posted by Doug
(Post 1995929)
I use a allen socket. I can just wiggle it into place and turn it with my thumb and forefinger. If the screw is very hard to turn (they often are) it's probably gummed-up underneath.....and the air passage is likely gummed-up as well. The fix here is to remove the air distribution block and clean things up. Order a new gasket first. On removal you'll see the 'over run valve'....which looks like a spring. Pay close attention to how it is installed so you don't reinstall it backwards https://cimg0.ibsrv.net/gimg/www.jag...2a0537f686.jpg Cheers DD What size socket would I need? The allen is a 7/32 correct? and is there anything I need to look out for when taking apart and cleaning the block? trying to find a gasket but no joy so far! thank you |
The gasket is part # EAC1743. Hit up the usual Jaguar suppliers
I think 7/32" is correct. Memory a bit hazy. I think the link I gave mentions the size Cheers DD |
(Post 1995950)
I think 7/32" is correct. Memory a bit hazy. I think the link I gave mentions the size Cheers DD just re read and yes 7/32. Currenlty have a cold so my brain is on and off. will hit up the gasket number tomorrow. Trying not to sound too like a noob but is is just air flowing through there correct? thank you |
Right. Just air.
Cheers DD |
