1988 Jaguar XJS Radio
Radio stopped working. I change the fuse in the radio (10 amps) and another one below the glove compartment , and still no luck, Is there other fuse i need to check ? Someone told me to check the radio relay. Where is the radio relay located at at what is it look like ? How will i know that my radio is already done. Anyway to check the harnesses ?
Thanks |
There is another 2A fuse located under the center console, which is also where you'll find the radio relay.
https://cimg6.ibsrv.net/gimg/www.jag...d8382149dc.jpg |
Thank you. I found this wire without the 1 amp fuse. I will attached the fuse back. Where is the other end of the blue wire (with the black tape) and the black wire attached too ?
https://cimg7.ibsrv.net/gimg/www.jag...5f4784ee1c.jpg |
I don't know what that is. IIRC, there is no blue wire in the radio circuit.
It looks like someone 'fixed' something, so you have some work to do to figure out how the circuit is supposed to be. You should download the schematic so you know what is what: http://www.jagrepair.com/images/Elec...Electrical.pdf Good luck |
