Gm400 gearbox
Old 07-22-2018, 12:19 AM
brinny's Avatar
Default Gm400 gearbox
can anyone tell me what the v12 gearbox is like in general for reliability? One or two threads lately about issues and I wondered if they are problematic? Is it worth having mine overhauled while the engine is out of the car? What sort of cost would be involved? Many thanks as always for your help.
Old 07-22-2018, 12:44 AM
Daim's Avatar
Received 2,180 Likes on 1,583 Posts
The TH400 is probably one of the most reliable transmissions ever made. As the successor, the 4L80E is also from 1st to 3rd gear also just a 3L80 (aka TH400) it is just as reliable. I mean, even Rolls Royce used them... And they were fitted from 1964 to 1998 by GM, some even til 2003. Mostly innheavy duty application.
They suffer from hard shifts from D to R or R to D. There are shift improver kits available. Depending on age and transmission fluid service status, I'd consider a rebuild. I'm doing one right now. Don't expect it to be cheap. And ypu won't really find a overhauled one, as the bolt pattern of the torque convertor housing is totally different to that of a GM V8.
ronbros (07-25-2018)
Old 07-22-2018, 12:45 AM
Greg in France's Avatar
Received 9,089 Likes on 5,352 Posts
In general it is one of the most tough and reliable autoboxes ever made. If yours has done 90,000 miles it would be worth a refurb; but if (say) 50/60,000 and you intend to do only a few thou a year at legal speeds, not really needed. A refurb by a decent place should come in at 1,000 - 1,200 UKP, especially if the box is out of the car and delivered by you to them. I know a really good guy in Luton, but I am sure there are places nearer to you.
Old 07-22-2018, 01:05 AM
brinny's Avatar
Thanks for the info lads. Mine has done 86,000 miles so may be ready. I don’t have a spare £1200 at the moment as the rest of the car has drained my wallet. Will change the fluid and filter and see how I get on. Hopefully it will be ok as miles will be low when she finally gets back on the road.
Old 07-22-2018, 05:58 AM
Robman25's Avatar
Unless the fluid looks burnt I would be inclined to leave well alone, there are a few horror stories of fluid changes causing problems, just my 2c.
Old 07-22-2018, 06:15 AM
Segfault's Avatar
When the fluid smells burnt then there is a burnt friction disk and fluid change won't fix it. Tip for used car buyers - sniff the fluid.
Old 07-22-2018, 07:27 AM
brinny's Avatar
Fluid looks a bit brown but no smell?
Old 07-22-2018, 09:08 AM
Doug's Avatar
Received 10,757 Likes on 7,101 Posts
The 400 is a tough old bird in terms of being able to cope with heavy loads and lots of torque ....but exceptionally long life is not a sure thing. Not unusual for a 400 to need an overhaul at 80-100k miles...though many go much longer, it's true. For almost all applications they were calibrated for smooth shifting....which increases wear on the clutch plates.
The best time to overhaul any automatic transmission is before it actually needs an overhaul. And certainly before actual failure occurs.
If done preemptively....or at the very first signs of getting weak....you can often get by nicely with a 'soft parts overhaul'. Clutch plates, seals, gaskets, new modulator on GP. Small stuff. If you wait till the box is slipping badly or has failed, you're likely into a "hard parts overhaul" where you need clutch drums, planetary gears, etc. Things start getting expensive.
Old 07-22-2018, 10:18 AM
Daim's Avatar
I'm still in the process of getting all parts together. I'm already at around €450 for besrings, clutches and co. Still need more parts... Just as a price reference.
Old 07-22-2018, 12:31 PM
ronbros's Avatar
Received 1,231 Likes on 939 Posts
the old GM 400 box was engineered back in 1962,released for sale in 1963, not bad for American engineering!
used by many GM cars along with Jaguar ,RR and some trucks , modified by some to handle 2500 lbs.ft. torque !
now we have its grand son 4L80/90E,,, ihave a Diesel suburban(ugh) with close to 200K on it, and trans is perfect, cant say that for the engine tho.
ron
Old 07-22-2018, 12:52 PM
Doug's Avatar
ron
And GM never saw fit, after all those years, to fix the notoriously noisy first gear !
Old 07-22-2018, 12:56 PM
JagCad's Avatar
Received 2,399 Likes on 1,880 Posts
Tis in the genes!!!
Our first post WWII family car was a 50 Pontiac fast back. Straight eight and three on the tree. Talk about first gear noise....
But, dad and mom kept it til he gave up driving. Passed it on my brother. He drove it for some more. then swapped it in for a pickup. used for used ??
Carl. l
Carl
Old 07-22-2018, 01:04 PM
Jagboi64's Avatar
Received 3,056 Likes on 2,031 Posts
It seems typical in Jaguar V12 service that the TH400 doesn't last much longer than 100,000 miles. The steel disks in the clutch pack typically break up at the scallops around the edge. When mine went then first and third gear were engaged at the same time, and that quickly burnt the fluid.
Greg in France (07-22-2018)
Old 07-22-2018, 01:20 PM
Daim's Avatar
I've yet to tear down my car's original TH400, but that transmission has 78.000 miles on it. The one I am overhauling has about 130.000 miles... I was told the car still drove with the snapped pressure plate, but on the other side: I can't say anything. Which is why I am striping it down. I'll probably use all the mechanicals of my proper transmission in the case of the old worn transmission. I doubt I'll be puitting 5.000 miles on her a year but hey, enough for a yearly service.
Old 07-22-2018, 01:25 PM
brinny's Avatar
Time will tell. My xk8 and xkr both had the famous jag sealed for life gearbox and I sat there with the thermal gauge after counting every drop in and out after a fluid change. Hope it’s going to be ok but on the plus side if it does fail me I know everything will be new on the way out!,,,
Old 07-22-2018, 01:32 PM
ronbros's Avatar
my suburban 4L80 has no noise from any gear,, 200K and holding! i actually tow with some times.
almost forgot, my Buick GN with LS2 and 4L80E , perfect all around street car, suspesion mods made it handle lightyears better, also 2002 Camaro brakes!
ron
Old 07-22-2018, 02:03 PM
Received 7,878 Likes on 4,762 Posts
Too bad you are not local to me in Texas USA. I have a NEW-IN-BOX THM400 (3L80) that I would sell for the price of a rebuilt unit.
It is still in the wood ship crate with steel bands. I think it was made in the early 1990s for all 5.3 XJ-S from 1989 onward.
Part number EBC3654N. I would guess shipping to Europe would end up costing more than you could get a reman locally.
I have a 1988 C2500 Chevy Pick-Up that has a THM400 and thought about stripping the Jaguar internals and putting them in the Chevy case but the truck is working fine so no point I guess. It would be a waste of a good Jaguar gearbox to fix a common Chevy truck.
bob
Old 07-23-2018, 02:01 PM
brinny's Avatar
bob
is is it worth doing the math?
Old 07-23-2018, 02:51 PM
Jagboi64's Avatar
Look into a freight forwarder/consolidator. If you can pick it up at the airport and do the customs clearance yourself ( which isn't difficult) airfreight can be surprisingly inexpensive. Door to door adds quite a bit to cost compared to terminal to terminal.
Old 07-24-2018, 11:23 PM
Daim's Avatar
The TH400 is a good half pallet item. They aren't super heavy but are a little on the heavy side to Lug around...
Quick Reply: Gm400 gearbox
