1994 XJS climate control not working properly
I have a 1994 XJS convertible that only supplies hot air through the vents. It may be no concern, but I have no vacuum present at the hot water valve supplying the heater core. Any suggestions?
Much thanks for any and all help! |
Originally Posted by Fr. Rick
(Post 2038763)
Much thanks for any and all help! Are you saying that heat comes out of the center vents no matter what selection is selected on the climate panel?.. defrost/no defrost? closing the slider on the center vents? |
Thanks for the quick response! Yes, there is heat at all times no matter what selection is selected; also it doesn't matter if in defrost no defrost, slider position of center vent, etc. All I ever have is hot air.
Rick |
(Post 2038780)
Rick Right selection knob; Off at 6 o'clock, Low at 7 o'clock. Med (Auto Fan) at 9 o'clock. High at 10 o"clock(not auto). 1200 o'clock defrost (full hot, high fan and auto opening of defrost to windshield, closing of floor.) Does your AC work? Can you confirm the heater valve closes when you select AC? |
I have diagnostic info for the AC if you PM with your email I will email them to you. For some reason I can not attach them to this post.
Originally Posted by warrjon
(Post 2038841)
warrjon, my email is rblassiter@cableone.net in the USA if that matters. Thanks fpr the help and info!
Rick |
Climate control
warrjon, my email is rblassiter@cableone in the USA. Thanks for your help and info!!
Rick |
All XJS models after 87 used the Delanair Mk3. There was an update an for MY94 covered in one of the docs I sent you
Originally Posted by carsnplanes
(Post 2038777)
No vacuum at the heater hot water valve is normally open positron all the time heat is selected as long as AC is not selected. Selecting AC supplies vacuum to the valve thus closing it it off. So, no vacuum,... valve open. Vacuum... valve closed.
Originally Posted by Mark SF
(Post 2038966)
That's not quite the complete picture. The valve is only closed if full cooling is required - if the temperature is in regulation, even with A/C on, the valve is open to allow warm air to be blended with cold air to achieve the desired temperature.
I know that late cars had some revised controls including, I think, an 'econ' setting (or similar wording) that cuts out the compressor
But in normal/full operating mode the idea is to refrigerate all incoming air first and then heat it as needed. This is done to dehumidify the air. That's why you don't see Jags driving around with fogged-up windows :) Cheers DD |
Fr. Rick again. I am afraid that I gave you the wrong email address. The correct one is richardlassiter@cableone.net in USA. Please send the info via this address and I am so sorry for the confusion.
6 Attachment(s)
Let me upload today. Here are the docs
I have a 1994 and the AC is not coming on like it did a week ago. Is there a way to turn on the AC independantly? I did turn the knob to select the coolest temp. But I get nothing. Selecting hot to cold does change the temp from ambient to hot |
With the '94, you should have the AC ON button at the top left--I assume you've tried that. And I assume you've checked for refrigerant in the system. What could be happening, and happens sometimes with my '92 (same basic Delanair Mk III) is that the aircon compressor clutch doesn't engage. I've found in that case, either turning the system off then on, or even better, turning it to full defrost then back to cold, kicks in the clutch. A weakening magnet is apparently the cause, if I remember rightly.
Doubtless one of the actual experts will chime in to tell you I'm quite wrong, but it does sound similar to my issue. |
Interesting! My car doesnt have the AC button. Probably because its an early 93 build. Where is the AC clutch relay located in the 4.0? Knowing this might help both me and the OP😁 |
Well it didn’t take me long to find the location. Its the one with a green base, on the right wing, in the engine compartment. Sure enough I gave it a tap and my AC worked! I immediately popped in a proper spare and its working like it should. Hope this helps the OP too. Thanks! |
Didn't realise you had a 4-litre, but glad you got it sorted. Sounds like you tried something different, but hey, it worked.
I didnt realize we were talking V12s til now either. Haha! They differ in many ways. |
