1995 XJS Convertable Aircon Compressor
Old Jun 14, 2017 | 10:50 AM
dhrudge's Avatar
Default 1995 XJS Convertable Aircon Compressor
The compressor on my XJS has packed up. I cannot see any labels or numbers on it - can anyone tell me what model compressor it is please.
Also, I am told there is an in line fuse in the power feed to the compressor relay - does anyone know where the fuse is please, I cannot find it.
Many thanks.
Don
Old Jun 14, 2017 | 11:24 AM
Vee's Avatar
Vee
Assuming you have a 4.0?
Sanden SD-709
If you add a signature, no one will ever ask you about which engine you have again.
http://www.jagrepair.com/images/Auto.../jvs1995en.pdf
See above link for electrical diagrams. There is indeed a Climate Control module, an AC Clutch relay, and probably some fuses to check?
Old Jun 15, 2017 | 01:26 AM
dsetter's Avatar
How packed up? Leaked, no clutch, noisy.
Mine was leaking at main shaft, was able to remove, replace seal, and rear o rings. Not to hard.
Need to vacuum pump down and recharge. Might need a dryer
Sep 9, 2017 06:52 AM
Don B
General Tech Help
17
Aug 8, 2017 09:11 AM
Sylvain
Oct 15, 2016 04:44 PM
Jan 20, 2011 04:14 AM
