245-60-R15 Tires
Hi all,
Has anyone successfully installed a set of these on an XJS? (They are only 10mm wider than the factory recommended tire size of 235-60-R15) Just want to make sure they fit as I prefer larger tires to fill the arches. Cheers |
Im interested to know to. I was looking into coil spring spacers if necessary... Even an extra half inch all around might be enough to fit the next size up
235/60R15s here fit fine. 245s would be a 1/2“ taller, and .3” wider. I think I have more than that much room left. What is the rim size range on the tires you’re looking at. And which rims? |
Can we convince you to measure on your car tires to see? I'd be concerned with rear wheel arch chafe, front might clear it even with wheels cranked all the way
Some interesting information...
The image below is out of my original vehicle manual It clearly shows the tyre size to be 215 70 R15 which has a large tyre diameter of 26.9 inches. These are readily available and are ideal for front tyres To get a wider tyre for the rear AND to match the diameter the 245 60 R15 works a treat which are also readily available. The suggested 225 60 R15 are way too small and you will increase your odometer or your car in no time as the wheels rotate much quicker per mile causing a higher reading on your odometer which potentially has the effect of adding unnecessary miles which may reduce it's value. I will attach more images below https://cimg0.ibsrv.net/gimg/www.jag...868d4c1c60.jpg |
Here is a comparison of OEM tyres vs 225/60R15
You can see a massive difference from the OEM tyre https://cimg5.ibsrv.net/gimg/www.jag...ee286d1513.jpg https://cimg7.ibsrv.net/gimg/www.jag...f107350ec9.jpg |
Here is the match comparison using 245/60R15 tyres
Almost exact match and will give a nice wide stance on the rear of the vehicle. Hopefully it does not produce Guard rub! I will keep you posted. https://cimg4.ibsrv.net/gimg/www.jag...f14956ec7c.jpg https://cimg9.ibsrv.net/gimg/www.jag...f1d335993c.jpg |
Another comparison here for anyone who is interested!
A standard mid 80's XJS with 215-70R15 tyres. (There is a sense of large paws with a solid stance) There is more wheel filling the wheel arch for sure. There is also more rubber on show due to the larger diameter. https://cimg8.ibsrv.net/gimg/www.jag...fb27a907d2.jpg Then there is the 225-60R15 such as the following image of Doug's vehicle (No disrespect Doug, just using your car as a comparison) Appears that the feet seem slightly gentler with finer lines due to the lower profile. https://cimg3.ibsrv.net/gimg/www.jag...2c3775a8e9.jpg |
No offense taken :)
The concern, not serious, is that the 6.5" wide original wheels are not really wide enough to properly support a 245/60 tire. They're borderline even for the 235/60 tires. It's not like something horrible will happen but you won't be getting the best out of the tire with the sidewalls pinched-in on a too-narrow wheel. A 245 would work better on a 7.5-8.0" wide wheel. But, you'll still have the look you want with wider tires Cheers DD |
Originally Posted by Crackerbuzz
(Post 1968933)
The suggested 225 60 R15 are way too small and you will increase your odometer or your car in no time as the wheels rotate much quicker per mile causing a higher reading on your odometer which potentially has the effect of adding unnecessary miles which may reduce it's value. Cheers DD |
Some information if anyone is interested...
Ok so in the last week I have been running 225/60R15 on the rear for about 2 days and noticed a MASSIVE difference in the vehicle handling from the original tyres which were also incorrect but slightly larger diameter than the 225 tyres. I noticed the rear of the car started to dive into the corners quite aggressively as if the car had been installed with 4 wheel steering or as if the rear shocks or springs had softened. I tested this throroughy on high speed corners on my local highway and to be honest I didn't like it at all. It was a little scary as if the rear was going to drop out and let go. So, I went back to my tyre guy and installed the correct factory 215/70R15 and the difference was incredible. MUCH more control in the rear with no more diving into corners. See below. Hankook 225's on the left and the Goodride 215's on the right. (Big difference in overall diameter - 1.3 inches to be precise or 33mm). IMO stick to the factory size tyre of 215/70R15! https://cimg4.ibsrv.net/gimg/www.jag...136289d113.jpg |
(Post 1970112)
Ok so in the last week I have been running 225/60R15 on the rear for about 2 days and noticed a MASSIVE difference in the vehicle handling from the original tyres which were also incorrect but slightly larger diameter than the 225 tyres. What size and brand were you running on the front? If different size and type, that might account for odd results. But, beyond a possible front-rear mismatch, it might well come down to the tire design more than the size. Lots of different brands and designs in that size and surely they have different characteristics. FWIW, I had no negative consequences going from 215/70 to 225/60. Cheers DD |
Originally Posted by Doug
(Post 1970323)
But, beyond a possible front-rear mismatch, it might well come down to the tire design more than the size. Lots of different brands and designs in that size and surely they have different characteristics. FWIW, I had no negative consequences going from 215/70 to 225/60. Cheers DD Front is running 215/65R15 which I haven't changed. Interesting you didn't notice a difference going from 215/70. Maybe the brand makes a difference. The 225's I bought were Hankook so should have been ok. I have replaced them with 215/70 Goodrides which are now what is on the rear of the car. Drives great now. (Fronts are also Goodrides but 65 profile instead of 70 profile) The rear was also running 215/65 when I bought the car prior to trying the 225's and changing to 215/70 Cheers |
my xjs had a factory 235 60 15. witch is the size im currently using. i have mostly come to the conclusion that i need to get away from a 15 inch rim to get a better tire. at 400 horsepower i already have traction issues. tread compound is just as important if not more so than tire width. there is a huge lack of tire choices in the 235 tire size basically your choices are a all season m/s tire or a more dedicated drag radial. i love my factory rims and don't want to change them. factory rim width is already borderline too narrow for a 235 tire. from what i can see the same availability problem in the 245/60/15 size. i would love to see someone come out with a sticker summer performance size tire that would work without going to a narrower
Originally Posted by Ezrider
(Post 1970648)
Would love that power, but gotta keep my 12 until it dies. |
Then... I will Big Block it!
496 probably |
its like having tea and crumpets smothered in Jack Daniels. when i bought my car i wanted a v12 now im glad i ended up with a 6 because the chevy power would spank even a v12 and i feel less guilty about swapping a 6cyl car. did my swap because i was having problems with the original powertrain and ultimately i wanted more power i don't regret it one bit. very soon its getting a supercharger should bump me up over 500hp
of course thats not going to help my traction problems at all...lol. hoosier makes some dot street drag radials in 235 60 15 but i really wish i could find more of a autocross type tire in that size. like a falkin azenis or similar. |
(Post 1970956)
of course thats not going to help my traction problems at all...lol. hoosier makes some dot street drag radials in 235 60 15 but i really wish i could find more of a autocross type tire in that size. like a falkin azenis or similar. Magnusun SC? That will keep it low under the hood and boost lots of power. Craig |
https://cimg1.ibsrv.net/gimg/www.jag...8b24af478b.png
These apparently come in 215 70r15 if its traction you want. Price is in Cad I think. |
wrong kind of traction....lol unless you are driving your xjs in the snow or offroad. less tread groves with a shallow tread more contact patch and a soft rubber is what you want for maximum traction in dry conditions witch is when i think most people drive there jags. some may want a all season tire that is better in the rain but i don't think many are looking for all terrain tires for there jags..... well i guess you never know.
(Post 1971058)
Love the analogy. Tea & crumpets smothered in Jack Daniels. Nice!
