84 XJS Earthing
Greetings
doing a check of the lights the other day and when i turn on the right turn indicator the right brake light stars flashing, front indicators are ok. i am guessing its and earthing problem, if ya all could direct me to the location of the probable offending earths. all good and thank you Regards Darren 84 XJS V12 - The Mistress. |
Classic sign of a bad earth. You will need to remove and clean all the earths in the boot. Download the electrical guide and it has the location of all the ground points in the car. I would concentrate on the ones in the boot.
Electrical diagrams found here JagRepair.com - Jaguar Repair Information Resource |
Further to Warrjon's points, the tail light unit earths right by the unit, I seem to remember, and this might be the bad earth, so worth looking at first. If nothing changes after that, or your car does not earth there, the unit is removed from the rear inside the boot, by undoing three small nuts from studs attached to the actual unit. But first remove the plastic lens from outside (two or three screws easily visible) and check that the bulb and holder are not rusty or dirty.
https://cimg1.ibsrv.net/gimg/www.jag...e554fc2ea5.jpg
HI cleaned the earth and also found corrosion on the bulb and holder and a sticky spring in the bulb holder .... thanks for the info Warrjon and Greg....all good and working now. attached is a picture of the tail light with the lense of showing the leanse seal in pretty average condition......what are the options to replace this seal....? \rehards Darren |
Hello Darren
Just did both my tail lights. Went to my local Bunnings store and purchased Double sided tape - commercial automotive mounting tape - water proof and high heat resistance (Permastik) and put this on the fixture Then put Moroday rubber rectangle 3mm x 6mm EPDM Sponge onto the double sided tape. (I did have to glue the seal join) I also placed aluminium tape behind and in top of the turn indicator bulb, just because the it was a bit dull Screwed in the lens. Has been raining extensively here over the last week - appears no water ingress https://cimg7.ibsrv.net/gimg/www.jag...03892c879e.jpg https://cimg8.ibsrv.net/gimg/www.jag...4f10fd3e45.jpg Cheers Steve |
Thankyou Steve .... on my way to bunnings ..... !
