92 XJS convertible 12. shimmy in front
Old 08-07-2018, 07:55 PM
jimmy and Tommy's Avatar
Default 92 XJS convertible 12. shimmy in front
Friends. have had the car about 1.5 years. at the beginning just a tad of a front shimmy. then it became much worse. Up to this point I have replaced upper and lower ball joints, new struts, alignment from supposedly best shop in town, new tires, new front bearings. some new bushings where it was obvious, replaced anti roll bar links. Nothing has worked. Now I am thinking could it be the rims? way back I did exchange the two front tires but I did not move the problem. Had purchased for wife as I already have an 87 coupe. It is too the point I don't want to drive it!!!!!!!!!!! Pls help. Jim
Old 08-08-2018, 01:15 AM
Steve M's Avatar
Received 2,918 Likes on 1,667 Posts
A bit obvious but have you checked your tyre pressures?
Old 08-08-2018, 01:25 AM
orangeblossom's Avatar
Received 3,751 Likes on 2,599 Posts
Again obvious
But did you have the Wheels Balanced, when the New Tyres were put on?
Jack up the Front of the Car and push and pull the Front Wheels Top and Bottom, if you've got any movement, it could still be the Wheel Bearings
Old 08-08-2018, 04:13 AM
Steve M's Avatar
Also could be steering rack mounts if they haven't been changed; does the whole car shimmy at the front or just the steering wheel?
Old 08-08-2018, 04:27 AM
macdoesit's Avatar
Banned
Could it be balljoints ? I once had a 67 VW bug steering wheel shook like crazy and it was balljoints.
Old 08-08-2018, 05:17 AM
leo_denmark's Avatar
I would take a look at the stubaxles. They wear on the underside and causes what feels like badly adjusted wheel bearings, you just can't adjust this...
Old 08-08-2018, 08:38 AM
VancouverXJ6's Avatar
Does the problem fade under hard acceleration or moderate cornering? You've thrown darts at everything else but there a few other (somewhat unlikely) things to consider.. Front subframe mounts front/rear and the steering column linkage itself.
We need a better description of exactly what it is doing.
Old 08-08-2018, 10:07 AM
Mark SF's Avatar
Please describe the shimmy in more detail. Does it telegraph through the steering wheel? Is it at a certain speed?
Old 08-08-2018, 10:58 AM
catterwaller's Avatar
Are the break rotors true? Jack it up and spin the wheels. Do the breaks drag and release?
Check the lug nuts for tightness.
Are the rims correct fit for the XJS?
Old 08-08-2018, 12:06 PM
jag-reflex's Avatar
Power steering leak?
Old 08-08-2018, 01:45 PM
Steve M's Avatar
I think he's left the building.
Old 08-08-2018, 02:44 PM
received new tires about one month ago. they balanced etc
Old 08-08-2018, 02:45 PM
good point. I am going to exchange wheels from the 92 to my 87 Jag coupe and see whats what
Old 08-08-2018, 03:16 PM
as soon as you reach about 15mph it feels as if the drivers side of the car has a shimmy. I can feel it through the steering. the amount of shimmy seems to stay about the same until you reach higher speeds. at 60 -70 most of it is reduced.
Old 08-08-2018, 03:17 PM
the shimmy is or appears to be generated from the drivers side only
Old 08-08-2018, 03:18 PM
I had upper and lower replaced
Old 08-08-2018, 03:19 PM
I am going to have these examined and will gladly replace if that will resolve
Old 08-08-2018, 03:20 PM
I am going to take car for a drive and detail every thing possible so additional info can be generated
Old 08-08-2018, 03:21 PM
this is something I have not specifically done but will be completing
Old 08-08-2018, 03:22 PM
the rims are the factory standard
Quick Reply: 92 XJS convertible 12. shimmy in front
