92 xjs hard brake pedal
Old Apr 22, 2013 | 06:40 AM
ukester's Avatar
Default 92 xjs hard brake pedal
Just purchased a 92 xjs and the brake pedal is hard like a rock-I was told that someone put something other than brake fluid in a while back and since then they have flushed the system. Looks like I may be replacing a few parts-my question is how many bolts are there when removing the rear cradle? Last question where is the best place to buy parts?
Thank you
Mark
Old Apr 22, 2013 | 07:17 AM
Welcome to the forum Mark,
I've moved your question from General Tech Help section to the XJS section. Members here will be able to advise on the cradle.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST section and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice on posting to the forum.
Old Apr 25, 2013 | 08:59 AM
ukester's Avatar
well I drove this home and the brake light is on as well as the abs light-brake fluid was very low as well. Put the car up and looked for some sort of leak none was found after filling the tank-started the car up stood on the pedal and still no leaks as well as the same rock hard brake pedal. Now where do I look from here?
Thanks in advance
Mark
Old Apr 28, 2013 | 11:21 AM
dsetter's Avatar
Sounds like some issue with the power assist system. This is provided by a fluid pump and a pressure accumulator. The accumulator fails at this age and the pump gets overworked and cannot handle the volume and causes the warning lights to be on. Can buy new accumulator for around $100.
Old Apr 28, 2013 | 03:00 PM
anjum's Avatar
Could be a problem with the connectors.
I had a bit of a senior moment when I first started my Saab after putting it back together (same brake system) and found I couldn't stop it safely.
A few minutes of head scratching and cursing and found I hadn't put one of the plugs back on!!!
Does the ABS run when you first turn the igniton on (you may to keave it off for a while first)? Does it run continuosly, it should turn off after a few seconds when it's got to full pressure?
Old Apr 29, 2013 | 06:31 AM
ukester's Avatar
it runs constant
Old Apr 29, 2013 | 07:05 AM
anjum's Avatar
Sounds like the accumulator is shot, at least. Or may be stuck valves in the pump, I seem to recall finding a write upon the internet about dismantling and cleaning the pump.
When you take it apart or take the accumulator off beware of high pressure in the accumulator even with the engine switched off.
Forcedair1
Sep 8, 2025 01:57 PM
mbergen
Oct 23, 2019 10:26 PM
PMKimpton
Aug 3, 2019 08:22 PM
hen555
Sep 7, 2015 11:13 PM
mikelibera
XJ40 ( XJ81 )
Sep 4, 2015 05:17 PM
