Air Conditioning - Needs work!
Hi All,
Ok, summer is coming here in New Zealand and my Air Con is a little worse for the wear. The compressor needs work and I'm not sure of the charge and if any leaks etc, Can anyone tell me what triggers the actual compressor to switch on and off as I don't seem to be able to see an actual AIRCON switch. I am guessing that the AUTO function on the RH control switch allows this to turn on as needed but I am not sure. Cheers |
Originally Posted by Crackerbuzz
(Post 1977513)
I am guessing that the AUTO function on the RH control switch allows this to turn on as needed but I am not sure. Since you have an '84 you'll have the 'superheat switch' protection circuit. If the freon level gets low enough the switch grounds-out and melts a three-prong thermal fuse. So, even if re-gassed, the fuse will need to be replaced. If the compressor is shot there are some modern replacement out there; worth considering. Be forewarned, though, that even if you get the refrigeration side of the system up-to-snuff it isn't unusual to have problems with the control side of the system. Some easy to trace and repair, others a real torment Cheers DD |
Thanks Doug,
Good info for me to start looking into. Cheers |
Hi all,
Can anyone give me some advice on this issue? The clutch plate seems to have dislodged? I am not sure how these work. Cheers |
Somewhat common failure on the A6 compressors. Decades ago it was common to replace just the hub and clutch. The parts are probably still out there with a bit of Googling. Most just replace the entire compressor these days; new or rebuilt....or new. upgraded design/
Cheers DD |
All parts are available for the A6. I rebuilt mine a few months backs. New clutch with bearing, plate and coil is like €50. I rebuilt mine for a total of €75. All new parts...
Thanks Daim, Where did you get the parts from? Cheers
Hey guys,
I have the option to get a later model compressor (Not the A6) from a 1994 6.0L XJS V12 car. Does anyone know if this is a simple swap or will I have difficulties? Cheers Craig |
Sorry, I got the parts from Centuryautoair and Rockauto. Just common A6 parts.
The later AC compressor will be an easyish job. You'll want the hoses and bracket to mount it (the rear one). |
(Post 1980959)
Hey guys,
I have the option to get a later model compressor (Not the A6) from a 1994 6.0L XJS V12 car. Does anyone know if this is a simple swap or will I have difficulties? Cheers Craig Not sure about the XJS 6.0L but the saloon uses a multi rib belt not a V belt |
Originally Posted by warrjon
(Post 1981156)
