Air temperature switch A bank side air filter box?
Hey guys,
what is the air temperature switch on the A bank side air box got for a function? It was fitted to engines from 64245 onwards... I wouldn't be surprised if it is a Marelli specific part... Number is DAC5061 Any ideas? Sure, temperature, but isn't that what the B bank temperature sensor is for? As it is a switch, something must be switched on/off!? Cheers Damien |
All I know is that my car ran poorly when it was disconnected.
Okay, so it serves a purpose, just what kind? ;)
Not quite the same part. What I am taking about isn't a sensor. It is a switch. A bimetal strip in a plastic casing...
But it might well be, that the switch was used on earlier models than the sensor shown in fig. 2 in your drawing... I could see if I can find a temperature at which it activates. If 25° then it is exactly that. |
The switch on the back of the A air cleaner is a bi-metal strip and closes at 75°C its function is to retard ignition at high temperature.
Cheers Warren!
Marelli only? |
1 Attachment(s)
Marelli only.
I've attached some Marelli info Cheers DD |
1 Attachment(s)
so what is this arrowed item please
its a soli valve, what its for no idea
Is that connected to the air pump?
no, I don't have an air pump as its an 84 uk car. 2 wires and 2 vac pipes though part no
is eac3488 |
Seems like something that wasn't carried over to an 89.
Originally Posted by warrjon
(Post 1653343)
