Another Marelli Ignition Caused Engine Fire?
Started my car and warmed the engine for 5 minutes from cold. Smelled burning odor as I pulled from curbside. Saw smoke and noticed lack of power. I immediately pulled into a parking lot and shut down engine. Passenger side catalytic converter was glowing red and caught something on fire, as ash and debris dropped under car. I called 911 and Fire Department responded to my location in minutes. Damage seems light, as flames burned out on their own,before the FD arrived. I had my car towed to my repair shop. Sounds like classic Marelli Ignition Failure to me. Hopefully it’s just the cap, rotor, coils to replace. Maybe The catalytic converters too? I don’t know yet what burned. The ash pile was small. Any thoughts? My last XJS also burned from a injection hose. I love this model, but may switch to a XKR if insurance totals car. I think it’s a simple fix. 91 XJS V12 Convertible, Classic Collection.
Almost certainly a Marelli fire. The CC will be toast too as they melt and block up. New HT leads and plugs as well as the things you mention, and it might be that the amplifier on that side it failing. I have no personal experience, but I seem to recall that the Aussies on here who have, say the failures are mainly due to not regularly replacing the plugs and HT leads.
Greg |
(Post 1890726)
Greg |
Originally Posted by Anglicomarine0326
(Post 1890743)
Greg...Can the catalytic converters be eliminated, rather than replacement?
THe Marelli 'fires' occur due to lack of maintance. How long ago did you check the ignition? When was the cap and rotor checked or even replaced? The parts aren't expensive. This is now going to be quite very expensive. |
Just got the car in late November, and only put 500 miles on it. It's been a well maintained car, purchased from the original elderly owner with 78,000 miles. I just changed the fluids, transmission filter, kickdown microswitch, and vacuum modulator. It's been running superb....then poof! Insurance should cover the repairs.
(Post 1890743)
May I make a reference to an article by Roger Bywater ( AJ6) on Marelli Failures ? He would claim the word "another" is misplaced.
Having experienced a Marelli rotor arm failure , I find the expression a "lack of power" somewhat understated. The expression "well maintained" has little relevance when the maintenance schedule does not advise the replacement of a part like this systematically. For the inconvenience a failure causes I would suggest a replacement of the rotor arm every few years. Any one wish to be more presice ? |
I was lucky, in my driveway,started car and noticed smoke coming from passenger side firewall and lack of power, turned it off. Distributor cap, rotor buttons bad, also replaced top coil, the bottom coil I can't get to it so I will jury rig the new bottom coil.
If I had been going down hiway fire would have surly happened. I still need to replace all fuel lines to the injectors. |
Originally Posted by rogerFF
(Post 1890811)
Having experienced a Marelli rotor arm failure , I find the expression a "lack of power" somewhat understated. The expression "well maintained" has little relevance when the maintenance schedule does not advise the replacement of a part like this systematically. For the inconvenience a failure causes I would suggest a replacement of the rotor arm every few years. Any one wish to be more presice ? I doubt many drive their V12 more than 5k miles a year. If you do, my respect! ;) My cars all had their plugs changed every 60k km or 3 years. As the V12 is less likely to run as well as a modern engine, a more frequent inspection is required. |
I did 7.5K mi. in my 86 coupe last year. I have to admit it’s getting better, a little better, all the time. My sympathies Anglico. Glad it wasn’t any worse! |
(Post 1890811)
Yeah, only some XJS enthusiasts and seasoned Jag specialists know to keep an eye on the Marelli ignition. It's an unusual situation. On most any other car a neglected ignition system may cause a variety of problems....but engine fire isn't one of them. Those accustomed to waiting for the car to 'tell them' when something needs attention are not expecting the message to come in the form of smoke and flames :) For the inconvenience a failure causes I would suggest a replacement of the rotor arm every few years. Any one wish to be more presice ? Spark plugs and spark plug wires play a big role as well. I'd say 24k miles on plugs and 48k on the wires....but that's a bit arbitrary. I dunno. But when in doubt, replace them! Cheers DD |
My car is still on its original cap and rotor 160Kmiles on the clock, The Marelli issue seems to be a USA phenomenon as I have not hear of any Marelli cars burning here in Aus.
Based on the 6.0L spare engine I have (came from a USA car) with less miles than my 5.3L and not one valve sealed properly, the whole valve train had to be replaced. I wounder if the USA cars with the cats in the downpipes caused a lot of these issues. |
It would be interesting (and rather reassuring!) if the Marelli fires are a US-only thing--pointing to something in the US spec, whatever that might be.
My cap and rotor were replaced at the beginning of the year, but it's not that easy to find caps at least these days (my rotor looks fine, so I kept it). And from what I've read, aftermarket parts are more likely than not to make things worse. I, too, wonder just when your cap and rotor were inspected last. There are, of course, various proposed preventative methods listed in Kirby Palm's book. For what it's worth, posts about people experiencing Marelli fires seem pretty thin on the ground here. Still, one of the first things I bought was a fire extinguisher, kept behind (or under) the passenger seat so I can get to it reasonably easily. Personally, I'd probably be more worried about old fuel injector hoses in a pre-facelift. Either way, the V12 will get you.... While I haven't had a Marelli fire, I have had one coil go out, and the loss of power when one bank stops working is very, very noticeable indeed. The car isn't sluggish so much as you wonder if the accelerator pedal actually is still connected. In my case, it was just after I started driving, so I managed to get the car back, by which time the Exhaust Temp light was on and the car simply stopped of its own accord. Some smoke from the bung coil, but no fire, luckily. Interestingly, Japan-market cars have an Exhaust Overheat warning light, which other market cars don't. There's an explanation on the sunvisor about what to do if it comes on (Stop the car! Now!). Hopefully, that'll provide some warning.... |
Originally Posted by Some Day, Some Day
(Post 1891908)
It might come down to the specification of the owner rather the the specification of the car. Lots of Americans have a nonchalant view of preventative servicing.* Plus, these old Jags are dirt cheap in the USA. People buy 'em because they're attracted to shiny objects...but don't have the resources and/or interest to fuss over them. Also, I'm betting that more XJSs were sold in the USA than any other market. This might skew our perceptions. Also again...is there such a thing as a Marelli XJS *without* catalytic converters for non-USA markets? If so, then there's nothing to meltdown, glow cherry red, and cook the car ! * I knew a guy, years ago, who bought a gorgeous XJ40 V12 for the wife. I warned him about the Marelli issues but his idea of 'proper servicing' went only as far as lots of oil changes and twice-a-month waxing of the paint. So in love with this Jag was he that a couple months later he bought a nice XJS...with Marelli ignition....for himself. More warnings from me. Sure enough, the XJ40 suffered a Marelli failure. Cost him a ton of money at the dealer for new converters....plus cap, rotor, tune up. More warnings from me. Ignored. Three months later the exact same scenario happened with his XJS! But.....those two Jags had the cleanest oil and shiniest paint you've ever seen :) Cheers DD |
Originally Posted by Doug
(Post 1891919)
I can't think of anything offhand....but I'm only two sips into my first cuppa coffee.
It might come down to the specification of the owner rather the the specification of the car. Lots of Americans have a nonchalant view of preventative servicing.* Plus, these old Jags are dirt cheap in the USA. People buy 'em because they're attracted to shiny objects...but don't have the resources and/or interest to fuss over them. Also, I'm betting that more XJSs were sold in the USA than any other market. This might skew our perceptions. Also again...is there such a thing as a Marelli XJS *without* catalytic converters for non-USA markets? If so, then there's nothing to meltdown, glow cherry red, and cook the car ! * I knew a guy, years ago, who bought a gorgeous XJ40 V12 for the wife. I warned him about the Marelli issues but his idea of 'proper servicing' went only as far as lots of oil changes and twice-a-month waxing of the paint. So in love with this Jag was he that a couple months later he bought a nice XJS...with Marelli ignition....for himself. More warnings from me. Sure enough, the XJ40 suffered a Marelli failure. Cost him a ton of money at the dealer for new converters....plus cap, rotor, tune up. More warnings from me. Ignored. Three months later the exact same scenario happened with his XJS! But.....those two Jags had the cleanest oil and shiniest paint you've ever seen :) Cheers DD Marelli fires are not common here BUT they happen. Again, due to neglection. |
Here is an excellent Post by 'Safari' on how to prevent a Marelli Fire
https://www.jaguarforums.com/forum/x...photos-135024/ |
(Post 1891919)
Cheers DD |
(Post 1890811)
V12 IGNITION SYSTEMS / AJ6 Engineering |
I’ll just add here that I experienced a cat meltdown that would have caused a fire had I not stopped when I did. It was cherry red and everything around it was smoking. This was in my 86 ( Lucas ). A short through the the top of the rotor button caused a multiple, intermittent, misfires but did not stop the engine. I think it’s the fact that the V12 can run on fewer cylinders and not be obvious about it that could allow one to continue running with a lot of unburnt fuel passing through the engine. Regardless of the ignition in question. Wouldnt happen in a four cyl. Damn thing would just stop. |
It might be an idea to list ways to detect if the V12 isn't running on all twelve cylinders.
Offhand, I think holding a card to the exhaust pipes works, or listening to the injectors clicking by holding a long screwdriver against them and your ear, but these aren't terribly useful while actually cruising down the road at high speed. Or any speed, really.... |
