Bad steering play!
Bad steering play!
the steering feels real bad and fairly dangerous. With all the other issues(it is a project) I haven't been able to look at the steering rack but know it's leaking somewhere. The steering play is really bad. While driving I'm always correcting and has so much play that I feel like I almost have to turn the wheel a few inches either direction depending... to where it feels like the wheel feels solid again. Example, if I was to take a left turn onto a road, once on to that road might have to turn the wheel 5" to the right to make it track straight and feel tight again. Sorry for the long vague question/explanation.
Besides the rack bushings I would bet that the suspension arm bushings are bad also. I have replacement planned for mine, but I have to do my XJ6 first. i am in the process of getting my garage back from my Wife. She's getting a large shed for her stuff. Can't wait! Don't want to tackle this in the driveway, my neighbors hate me enough already!
Little question by the side: have you had some new tires fitted? Did the steering become 'vague' after that? If so, then try putting the rear wheels to the front.
I noticed on my XJS and my X308 that certain tires least to a 'floaty' front end and the need of correction over and over and over again.
+1 for rack bushes, polyurethane bushes here are a must and sharpen up the steering significantly without too. much NVH.
Leaks in the PS from my experience are either the JIC fittings, low pressure hose on the pump I double clamped mine and it still leaks, or if it's the rack its self then it needs refurbishing
I've used Superflex from the UK and they were good.
https://www.superflex.co.uk/proddeta...=SF211-0083KSS
The absolute best rack bushings are the JaguarSport ones. They are still available from JCP and will last a lifetime or longer.
Greg in France (11-11-2017)
Received 10,749 Likes
My standard bushings were dry, and completely intact. However, I could easily move the rack through the full range, prying with a screwdriver. My conclusion is that the original bushings are a poor design.
Spent the last few nights changing them to poly. This job counts as "not fun" if you don't have a lift.
The ones I put in cost $20 on EBay. The brand is Nolathane. The kit looks exactly the same as the Whiteline one, and both companies have the same parent, so I suspect they are the same.
Another reason to use them is that polyurethane rubber has better oil resistance.
Greg in France (11-12-2017)
