best rust prevention method
Hi,
I plan to drive my 1994 XJS in the winter in NY. What's the best way to prevent rust? Thanks. |
Any other way you would prevent rust on any other car. |
Get it professionally Waxoyled or Dinitrolled or similar.
The other option is to buy a winter car and lay the XJS up; it may work out cheaper in the long run. |
The body & floor might last a few NY winters, rust proofing or not. The IRS maybe two years, the felt seals won't hold the salty slush out either. The radius arm's might as well be "welded" to the sub frame. Some guys spray the under with oil. Don't know about that until you need something welded or apply heat to a frozen nut or drive down a few dusty roads. Best advice; "winter rat". Check out some back issues of Jaguar World Magazine .
Corrosion Manual.pdf This is a care manual for snow plows created by Montana State University, published by the Minnesota DOT.
The DMV also has recommendations: DMV.org |
Lanolin................ It'll never rust. I use Lanox it's an Inox product. Where I live everything in my shed rusts in winter, nothing comes into my shed without being given the Lanox treatment.
I also spray both cars with it, smells like a shearing shed for a while, but it's cheap and it works. I have a dozen sheep in the back yard and the fences are as good as new been there at least 20 years. |
warrjon,
seems like a great product. gonna pick up some at local harley dealer and give it try. just out curosity, how much is it in Australia? thx |
I bought it from the local hardware store (100km round trip away) it was about $13......
Originally Posted by Steve M
(Post 1939330)
The other option is to buy a winter car and lay the XJS up; it may work out cheaper in the long run. buy a winter car car for sure . Do the rustproofing yourself. You know where you stand then. |
Originally Posted by warrjon
(Post 1939607)
Best rust prevention. Don't Drive It !!! If you drive it. It will Rust ! The best you can hope for, is to slow it down. Blunt but true.
Jack |
I drive my car in Vancouver in the winter, rain (6 months of it) and the occasional snow day. I periodically spray the underside with rubberized stuff as any car would have a similar undercoat treatment, and followup with a more temporary spray of this goopey anti-corrosion stuff, its essentially goop and a kind of oil film that sticks to metal and lasts a few months.
If you've got money to burn and are dead set on winter driving you could go and have the entire underside sprayed with truck bedliner in maximum thickness. I'd imagine this would involve removing any existing coatings and carefully isolating certain components to be individually sprayed afterward. I had thought of doing something like this on the sill/rocker panel as you can get colour-matched (bright signal red) bedliner sprays and just do that on the bottom sides of my car. Of course nobody sees the underside so cheap black is good enough. |
Does anyone have any experience with Dinitrol RC 900 Rust Converter Does it really work? I've noticed some rust appearing around the door sills on my XJ and looking to repair myself
This is how to rustproof an XJS for European winters, but you must do the work in summer:
Originally Posted by VancouverXJ6
(Post 1940546)
If you've got money to burn and are dead set on winter driving you could go and have the entire underside sprayed with truck bedliner in maximum thickness. I'd imagine this would involve removing any existing coatings and carefully isolating certain components to be individually sprayed afterward..
(Post 2095452)
Spray Lanox (or any Lanolin spray) into all the nooks and crannies once a year and it will never rust.
I use Lanox on all my machines, measuring equipment and tools. It will also remove surface rust. I had surface rust on my lathe chuck sprayed with Lanox and a light rub with 000 steel wool and its gone with no trace. |
My XJ-S has an undercoating of 30 years of oil leaks. No rust anywhere near the oil. ;)
One of the best things you could do in addition to the typical methods mentioned here is to routinely rinse the car. Buy or make an underbody spraying system to aid in this and very regularly rinse the salt off the car.
More critical than all the coatings on our boats is thoroughly rinsing them when we come back in. It makes a big difference. |
Originally Posted by Daim
(Post 2096273)
bob |
