Jaguar Forums - Jaguar Enthusiasts Forum (https://www.jaguarforums.com/forum/)
-   XJS ( X27 ) (https://www.jaguarforums.com/forum/xjs-x27-32/)
-   -   Check Engine Light (https://www.jaguarforums.com/forum/xjs-x27-32/check-engine-light-65172/)
mrtalkradio Dec 19, 2011 05:34 PM
Check Engine Light
I have a FF36, I read what it means, but I haven't a clue where to begin and diagnose the issue. Any guidance here would be appreciated as always.
warrjon Dec 19, 2011 07:12 PM
FF36 is a fuel injection fault in the B bank. This code is set when the maximum fueling correction is applied either high or low. It is part of the closed loop including the O2 sensor. I would start there (o2 sensor). Check the connector and wiring for faults, you could even swap the sensors from one side to the other if you get an FF34 A bank then the sensor is faulty.
cheers
Warren
© 2026 MH Sub I, LLC dba Internet Brands
