Differential, rebuild or replace???
HI all,
It appears that the output shaft on the left (driver) side of the 94 XJS is going out. There is a noise and the tire rocks a bit too much. I took it over to a brake shop (hoping the brakes had an issue), but the brakes are great. The fellow says I should replace the whole differential otherwise I will have the same problem on the other side at some point. So, any thoughts? Should I just seek to get that side repaired or seek out a whole new/used/rebuilt diff.. Any recommendations as to where and best price to get one? Thanks, Tony in NM |
Originally Posted by dtony
(Post 1488252)
HI all,
It's a lot easier to replace the stub axle bearings than to replace the diff!!!!!!!!!
The output shaft bearings can be replaced with the diff in-situ. Just tilt the halfshafts out of the way, the rotors are already moved outboard on the 1994MY. bob |
Can one buy a complete stub axil (aka the output shaft) and it's plug n play. Or what parts would I need to rebuild the axil myself?
Tony |
