Fan shroud mounting question
Hi !
Take a peek at this illustration and note the mounting tabs at the top of the shroud..... Cooling Fan Cowl-Mechanical-5.3 Litre - Parts For XJS from (V)139052 to (V)179736 | Jaguar Classic Parts UK Here's my question: Should there be rubber cushions at those mounting points? The illustration doesn't show any, and frankly I don't recall removing any. But I have a nagging thought that those holes should have those round grommet-like cushions as used in various other locations. Thanks for any help Cheers DD |
Hi Doug,
As I removed mine, there were no rubber mounts or rings or so for them... So I'd say you ought to let go :D |
Originally Posted by Doug
(Post 1462895)
Hi !
Take a peek at this illustration and note the mounting tabs at the top of the shroud..... Cooling Fan Cowl-Mechanical-5.3 Litre - Parts For XJS from (V)139052 to (V)179736 | Jaguar Classic Parts UK Here's my question: Should there be rubber cushions at those mounting points? The illustration doesn't show any, and frankly I don't recall removing any. But I have a nagging thought that those holes should have those round grommet-like cushions as used in various other locations. Thanks for any help Cheers DD No rubber mountings on mine and the Shroud has never been out. https://cimg9.ibsrv.net/gimg/www.jag...7ceb905566.jpg https://cimg0.ibsrv.net/gimg/www.jag...ecc3cfb1fe.jpg |
Both of mine were rubberless waaaaaay back before Efans.
I know those rubber units you remember well. They are not used here. |
On my 1985 the shroud fixing holes had rubber cotton reels OEM. The holes on the shroud fixing brackets were quite large, and without the rubber and a washer on top before the fixing nut, the shroud would have fallen off. Maybe it was changed at some point?
if you have an main electric fan in place of the engine driven one, attached to the shroud, some sort of damping is quite useful to prevent vibrations into the body. Greg |
(Post 1463288)
Yeah, the large holes are just begging for the 'cotton reel' mounts! That's why I had to ask ! But..... The large holes, left rubberless, give you quite a bit of adjustability when positioning the shroud if you have an main electric fan in place of the engine driven one, attached to the shroud, some sort of damping is quite useful to prevent vibrations into the body. I'm going with 'rubberless' mounting on the shrouds themselves Cheers and thanks DD |
(Post 1463359)
The large holes, left rubberless, give you quite a bit of adjustability when positioning the shroud DD Greg |
(Post 1463395)
The legendary NVH experts of Jaguar's illustrious past will be turning in their graves...
Greg The e-fan assembly is mounted to the 3-leg bracket using the rubber cushions, and the bracket-to-shroud mounting uses the rubber cushions as well. Cheers DD |
