fan shroud sealing strips
Greetings everyone.
On the fan shrouds, both mechanical and electric, there are sealing strips, Jaguar part number C379411, that keep the shroud from sawing through the radiator, as well as most of the air in the shroud. Any body have any recommendations for replacements? Of course they are unobtainium from any of the usual sources that I have found. I would assume something from a supply house like McMaster Carr would have something, tricky bit would be matching it up. |
I would think something like this would work:
Just cut to length to make it fit, protecting the sharp edge of the sheet metal. |
I Ibought some stuff off eBay that was similar. Think it was 14mm from memory. Try a search.
Well that was easy, Thanks Mac, I'll let you know how that stuff from Amazon works.
