Jaguar Forums - Jaguar Enthusiasts Forum (https://www.jaguarforums.com/forum/)
-   XJS ( X27 ) (https://www.jaguarforums.com/forum/xjs-x27-32/)
-   -   Help with handbreak (https://www.jaguarforums.com/forum/xjs-x27-32/help-handbreak-203300/)
MIFoodie Jun 13, 2018 10:59 PM
Help with handbreak
I need to remove the handbrake at the rear calipers and cannot pull the two "arms" together to get slack and release the cable. I have tried to locate the adjuster nut at the driver carpet and I have read where it is and also seen closeups but cannot find that on my car. What gives with that?? I do find a large nut and have tried to remove that but thought better and decided to tighten it back up. When I use the handbreak I get no clicks and the arm moves freely.
Can you help?
orangeblossom Jun 14, 2018 01:23 AM
Hi MIFoodie
Fear not the Handbrake adjuster is inside the Car although it is a bit fiddly to get to and slacken off, where you have to undo a Locknut and then once that is done
Slacken off the adjuster one turn at a time, which seems to take for ever and so a lot of patience is required
Once you've got that Slackened Off then you should be able to pull those arms together a lot easier
Have a look at this Photo, which I took when I adjusted my Handbrake
https://cimg3.ibsrv.net/gimg/www.jag...f1ee82d440.jpg
It is a bit of a fiddly job, you just need lots of patience and you'll get there but first undo this Lock Nut on the Adjuster
https://cimg8.ibsrv.net/gimg/www.jag...820e369d82.jpg
The Handbrake Adjustment Rod is just behind the Drivers Seat underneath the Carpet Trim and can be a bit hard to find
© 2026 MH Sub I, LLC dba Internet Brands
