How To measure temperature
As this is a question that comes up a lot on this forum, I thought I would do a write up on temperature testing using both an infra red thermometer and a K type thermocouple.
I did this testing a while ago when I was working in a military calibration laboratory.
The write up in PDF so it can be downloaded. Please feel free to as questions.
The following 7 users liked this post by warrjon:
Don B (04-07-2017),
Eaa (04-07-2017),
Grant Francis (04-07-2017),
jp72 (04-07-2017),
Mac Allan (04-06-2017),
and 2 others liked this post.
Most IR pyrometers are set at 0.95 emissivity from the factory, even the Fluke, although these expensive IR's have user setting to adjust emissivity.
0.95 is fine and on the Fluke 572 changing to 1.0 only makes a few deg difference.
Most important thing to be aware of is DTS (distance to spot ratio) if you hold the IR too far away it will measure everything in its spot. As was mentioned try to avoid shiny surfaces, black is best.
I dunno kid. Hokey gizmos and ancient electronics are no match for a good temp-label on your hose.*
Perhaps something like this....
Temperature Labels
*Disclaimer: I have no idea if this is actually true of course. But they seem like an interesting idea...
"Handyman Solo. I'm mechanic of the Jaguar XJS. Louie here tells me you're lookin' for passage on the Interstate system?"
"Yes indeed, if it's a fast car."
"Fast car? You've never heard of the Jaguar XJS?"
"Should I have?"
"It's the car that made the Kegger Run in less than twelve breakdowns. I've outrun State troopers. Not the local bike cruisers mind you, I'm talking about the big Crown Vics now. She's fast enough for you, old man."
Temperature Labels
"Should I have?"
Actually I do do that. Or more like a gentle touch when it comes to the hotter parts....
The problem is, I don't know the difference between really hot and far too hot....
Mind you, when I first drove my car, and was having problems with it getting too hot, I needed an old towel around my hand to release the bonnet catch as the heat was searing. After the new rad and hoses and thermometers, which were done basically as soon as I got her, I can reach in bare-handed, though there's a definite different between a run where she doesn't reach full operating temperature (usually due to not being too long and having good flow through due to speed, not due to just driving for five minutes and stopping) and a run where the thermostats kick in (I assume) like in heavy traffic or hotter days or faster driving.
ronbros (04-08-2017)
