How to open the boot without a key
Ive retrieved my car from this shop thats had the car for 6 months. Car is completely locked. No keys in site.
And of course the spars I had made years ago dont work. How does one open the boot without keys? |
Hi Scott
Maybe you need a Locksmith? Cannot imagine any other way in |
Scott,
Have a look on the parts diagram on the Jaguar website and you'll see that a rod connects the boot lock to the boot latch. A carefully drilled small hole just off centre behind the number plate and you should then be able to use a bit of wire to pull the rod and activate the boot latch. Good luck Paul |
Thats what I found when googling today. Im going to try this tomorrow
before you do that... have you lost the key ? or do you know that the key uses 3 positions in the lock. locked, unlocks with doors and,unlocked
I gave the key to the shop 6 months ago. When I came back stateside this weekend I found the car on the street. Locked w no keys anywhere
OK then try this get the original key numbers and history of your car.
https://www.jaguarheritage.com/archi.../certificates/ or this for the trunk boot lock https://www.ebay.com/sch/i.html?_fro...coder&_sacat=0 |
I used a hole saw and then inserted as grommet, you can see the screw inside this is the rod that opens the boot.
https://cimg7.ibsrv.net/gimg/www.jag...78c5e9829a.jpg |
