let's talk headers.
So I am getting my header flanges waterjet cut, and I am getting the ice engine works mock up kit,
They will be 1.625 tubing So should I do 6 into 2 into 1 like the traditional headers. Or, 6 into 1 like aston Martin v12 headers are built like? Any other suggestions or input would be wonderful |
I truly have no idea!
Everything I have read and seen, says Jags system is good, never heard of headers helping. For the life of me, cant remember where I saw it, but a shop in the UK has a kit that uses 2 balanced and tuned downpipes, plus the entire exhaust in ss if you want it. They have a great site with info about such things. Can anybody help, before Calvin sinks money in? |
2 Attachment(s)
Have you considered this approach? Should look great with a set on the other side too.
Loooooooooooooooooool
2 sections means less chance of warping and it will be easier to remove and install
2 Attachment(s)
Originally Posted by Steve M
(Post 983480)
Attachment 85720 |
I would be going down the path of what Lister did, I believe and even they said there is a lot of HP to be made out of the exhaust alone. The way I am thinking for mine is two banks of 3 connect cylinder 1-2-4 and 3-5-6 then like the original 2 to 1 and exit. I think room is going to be the issue here and the above sequence will most likely give you the closest to having all tubes the same length. I plan to nearly duplicate as much as I can the original setup but just have those tubes longer but coming to the same point under the car.
6 Attachment(s)
Originally Posted by calvindoesntknow
(Post 982834)
They will be 1.625 tubing So should I do 6 into 2 into 1 like the traditional headers. Or, 6 into 1 like aston Martin v12 headers are built like? Any other suggestions or input would be wonderful Feast your eyes on this gorgeous bundle of snakes Attachment 85722 Attachment 85723 Attachment 85724 |
Those are Marko's headers. lol
Originally Posted by M90power
(Post 983853)
Captain of The Black Pearl. |
is he on this forum?
Pure art!
(Post 984052)
I'm going to make a setup that looks similar to that, and the lister setup.
We'll see how it comes out. |
4 Attachment(s)
I was thinking about going for these , removing the exhaust as quickly as possible in these cars because of the restriction is key. The Ferrari headers are 44 primary tubes not sure about the other photo
| All times are GMT -5. The time now is 09:55 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
