little hose above the oil pan and near oil filter
Old Dec 2, 2013 | 07:52 PM
dtony's Avatar
Default little hose above the oil pan and near oil filter
Hi all,
I have a 90 XJS convertible. I got a lot of oil loss on the interstate the other day. After filling the oil back up, I got it home and found a very short rubber hose that snapped just above the oil pan. It is in a very tight spot and I have been trying a variety of methods to get at it.
Does anyone know of an easy way to fix this without having to take the rack out?
Thanks,
Tony in New Mexico
Old Dec 2, 2013 | 08:39 PM
JagZilla's Avatar
That's a tight area to get to. The rack can actually drop several inches, fairly easily, without being removed. Doing that may give you the extra room you need. Unfortunately, it's been several years since I had to do that, but, it seems that you can do it by removing two of the bolts that secure the rack bushings.
If that doesn't let you get to it, you'll have to also remove the downpipes on that side. One of the few tasks that suck worse than removing the downpipes is putting them back on. It seems that at least one of the 4 studs on the manifold is located in a place which makes threading that brass nut onto it, nearly impossible. Patience and persistence are the keys.
Old Dec 3, 2013 | 08:34 AM
dtony's Avatar
Thx for the info. I just put the rack in a couple weeks ago. Being that was a two month process for me, I was hoping to not have to fool with it again. Such is life.
Tony
Old Dec 7, 2013 | 06:37 PM
dtony's Avatar
Default Got it done!!!
Hi all,
It took me a couple of weeks, few odd shaped tools, a lot of determination and a plan, but I got that little hose done without having to remove the rack or cats. So far no leaks. I just hope it holds.
Thanks for the input and I look forward to future chats.
Tony in New Mexico, USA
Attached Thumbnails little hose above the oil pan and near oil filter-fb_img_13693532105845372.jpg
Old Dec 8, 2013 | 04:16 AM
Caught up with this today, slack I know.
I did ours and that is one task where the RHD makes those 2 hose simple to do in the big scheme.
The downside is our starter motors are a PITA to get at, and worse to get out.
Tony, you mention "that hose", as in singular???. There are 2 small hoses in there, one on each end of that metal pipe, UNLESS the USA market cars are different to ours??.
Old Dec 9, 2013 | 06:14 AM
dtony's Avatar
Yes, there are two, but only the one close to oil pan needed the replacement. I'm convinced that Jaguarbdid not intend for DIYers to work on these cars.
Tony
Old Dec 9, 2013 | 07:36 AM
JagZilla's Avatar
You would have probably saved yourself a headache if you had replaced them both while you were there. Knowing Jaguar rubber the way I do, the heat in that area has made the other hose just as brittle as the one you replaced, and it too will be leaking in no time.
As hard as these cars are to work on, it pays to get into the habit of looking at everything in the area where you're working, even if it is an unrelated part. If it looks like it might be nearing the end of it's useful life, go ahead and take care of the problem while you there, rather than having to go back a second time. This is especially true of any British rubber pieces. They don't stand up well to the heat, and have most likely been on the car since it was built.
In fact, as a matter of practice, you should go ahead and buy a complete set of coolant hoses, and replace them all as soon as possible. I believe there are something like 15 or 16 of them on the V12, and you can find vendors who will sell you the complete set, so you don't have to spend hours looking up and ordering individual part numbers.
Old Dec 9, 2013 | 11:04 AM
rgp's Avatar
rgp
assuming its a v12
imo you chould take the whole filter head off as there are o rings that will need the same attention due to age I had the same thing on mine and while the rack is lowered (in your case) it would be short sighted not to do them.
all still available from jcp
Attached Thumbnails little hose above the oil pan and near oil filter-oil.jpg
Old Dec 10, 2013 | 03:47 AM
dtony's Avatar
Yes indeed. *I recently replaced the rack and while doing so replaced both
those hoses. *They were easy when there wasn't a rack in the way.
Unfortunately, I put the one back in on the wrong side of the pipe leading
to the oil filter mount. *Thus rubbed against the steering column and
stressed the hose.
So hopefully, neither will be an issue for a long time.
Tony
Old Dec 24, 2013 | 04:37 AM
dtony's Avatar
Default Leak is back
Well this is the pits, but I was out and about yesterday and noticed that my oil leak (from the same area) seems to be back. I made sure there was oil and got it home. Put it in the garage and will ask Santa (aka Father Christmas) for a couple of ramps to drive it up on (actually, he already dropped them off). Likely won't get to it until after Christmas day.
Assuming it is the same hose again, I was wondering if there is any special type of hose to use? I used a narrow fuel line that was a tight fit over the spouts. Should I have used something else?
Tony in NM
Old Dec 24, 2013 | 05:32 AM
OH.
Fuel hose would be OK to get you home from, say, Vegas. It will not last long, sadly, as it is simply not designed for oil.
I use a Pirtek 6mm Red oil hose, rated at 1500psi (a tad overkill, but it is OIL hose), with EFI005 clamps. Pirtek is a hydraulic mob down here, along with Enzed, and are within walking distance of my work.
My HE has had them there since 2000, and still soft are pliable, last time I changed an oil filter. NO oils leaks on that beast.
Old Dec 25, 2013 | 09:42 AM
dtony's Avatar
This may be a silly question, but if I use the hose you recommend, do I still need to use the metal tube in between?
I found the company you mentioned located in Phoenix, AZ or Denver Co. Their specs say the hose can stand up to 300 plus degrees. I assume the metal pipe was to handle the heat between the hose lengths.
Thanks,
Tony in NM
Old Dec 25, 2013 | 11:56 PM
Tony,
I see NO reason for that metal tube, never have worked out why it was done that way.
My warped sense of humour, loooooooong time ago, decided it had 2 hoses, with 4 joints, to allow for more oil leaks. Made perfect sense at the time, and still does today.
Mind you, I have NOT deleted that pipe on any of my V12's, just replaced the hoses with that Pirtek stuff, and never ventured to that area again.
Maybe the "British non-metallic" component, the hose, back in the '70's was of poorer quality to what is available today, so 2 short straight sections, with NO bends, was seen as as the lesser of 2 evils.
silkcat
Jan 18, 2025 04:29 AM
aholbro1
Dec 29, 2024 06:46 PM
tomsjag
Jun 10, 2023 10:02 AM
Jandreu
Jun 30, 2022 03:10 PM
Wes Steenrod
Sep 6, 2015 06:52 PM
