Where on the planet are you?
Missouri, USA. I know I will probably have to ship it. They want $200 for a new clutch master cylinder. I saw a free posts about rebuild kits and thought I’d go that route. The car has 86000 miles on it
Originally Posted by bladerunner919
(Post 1909086)
Slave cylinder location
where is the slave cylinder located. I think I am ready to bleed the clutch. I found the leak on the master cylinder( the reservoir was had a crack) fixed it and cleaned the cylinder out. It builds up pressure on the my desk. I can not locate the slave cylinder though. As I have said before I work on vintage US cars. https://cimg5.ibsrv.net/gimg/www.jag...2ba3effcc7.jpghttps://cimg9.ibsrv.net/gimg/www.jag...ca4e0e8fed.jpg
I fixed it!!!! Even took the big cat down the road. |
That switch on your steering column looks a lot like the "valet switch" for the alarm on my car - 91my - cant tell if its in the same place though. I'd guess that's what it is.
Originally Posted by Eaa
(Post 1913811)
Hi Andy
Well done Bro but what was wrong and how did you fix it? |
Originally Posted by orangeblossom
(Post 1914044)
Hi Andy
Well done Bro but what was wrong and how did you fix it? The leak at the master cylinder was a small crack in the reservoir cases by the rivets being pulled to tight at assembly. I cleaned and epoxied the crack. It it took a couple hours to bleed the system and two days for the epoxy to fully harden. The jag runs better the more it’s let to run. |
Well done Andy!
You got there in the end |
