The Lord of Darkness hits again
As most of you know I have spent the last 3 years cleaning and going over the electrics under the hood/bonnet. Finnally had a chance to get the XJS out earlier this year and running great. Well last week we had some very nice cool days and decided to do some wiping down under the the hood and then take it out for a bit of a fun drive, just by chance I left hood up so I can chck the fluid, went to start it up so I can check the tranny fluid and notice a small leak from a fuel hose. No problem, just tighten the clamp a bit (just glad had the hood up and spotted it). Anyhow, went to satr it to make sure of no leaking and it was a no go, no start.
So, found no spark. Nothing Nada, Zip. No spark from plugs, and nothing at the coil, changed out the coil with a spare and still nothing. (have updated to the single coil. so now to get back down and star checking the ignition system and locate the fault, just took some time from it I guess out of some frustration and getting a bit disgusted. I will beat you Lord Of Darkness. :icon_poop: |
Could this be a dreaded shielded wire issue? Sounds like it!
OOPS.
Cleaning under the bonnet has upset the gremlins. They may settle when you leave them alone. Ign ON, is there 12v at the coil +ve??. If there is, good, maybe. Now crank the beast, and note if that 12v drops out, or very low. If it does, the Ign Switch electrical section is having a hissy. Getting very common now. Lets know and then we can move on to plan B C D .......Z |
Originally Posted by Daim
(Post 1737912)
Originally Posted by Grant Francis
(Post 1737960)
OOPS.
OK that Lucas .
Quickie check is supply 12v to coil +. Try her now.
(Post 1737912)
the 2 prong connector that hooks up to the connector for the dizzy had a couple of sma;; breaks that were not noticed before. So time to make one up, I found a couple of places on EBay that has some 2 wire shielded, just need to see what gauge I need |
The Lord of Darkness is always lurking
