Low beam headlight not working
Greetings,
Discovered the left side low beam headlight does not light up. However, when I switch to high beam all 4 lights are on. What!! Anyway, I checked the fuses. All are good. So any tips about what to test next are welcome. ok, this is on my 1990 XJS V12 Convertible. |
It has to be one of the following.
- Fuse 4 in the black fuse panel in the engine bay - Connectors on fuse 4 or to the low beam lamp - Faulty low beam lamp. According to the electrical guide there are 2 bulbs one is high beam only and the other dual high/low beam when high beam is on low is off what you are seeing is the high beam part of the dual bulb. |
The low beam bulb has two filaments. I believe that the low beam filament is burned out. Try replacing the bulb.
Thanks. I’ll test the bulb itself.
