Go Back  Jaguar Forums - Jaguar Enthusiasts Forum > Jaguar Models ( Classics ) > XJS ( X27 )
Reload this Page >
Newbie to Jag 99 xj VX vanden plas.. need advice
Old 05-11-2019, 11:28 PM
Default Newbie to Jag 99 xj VX vanden plas.. need advice
I've had this car a few months beautiful car. Last few days will sometimes not turn over, just a click by passenger front sounds like and also from sounds like the cigarette lighter sometimes?? Message center reads low coolants(nearly full, doesn't overheat) & Traction control failure, or a couple times said Pecus with a t below. Will start after a few tries of going through the system check cycle after turning key. Usually strong starter and runs well. Have noticed a small jolt upon acceleration if you try to accelearate quickly. Always run premium. 160,000 miles ..not sure what this could be, any suggestions???
Old 05-11-2019, 11:53 PM
Jagboi64's Avatar
Received 1,050 Likes on 783 Posts
The internal Jaguar code for your 1999 Vanden Plas is the X308, you need to look at this forum: https://www.jaguarforums.com/forum/xj-xj8-xjr-x308-27/
The cars here are several generation older and share nothing between them and your model. All that being said, how old is the battery? If it's older than 5 years, replace it. It might also be a good idea to put it on a battery charger (CTEK is a great brand) and try charging the battery. All sorts of electronic weirdness is often associated with a weak or low charge battery.
Old 05-12-2019, 12:05 AM
Thank you and the battery was replaced a few months ago
Carnival Kid
05-06-2019 02:50 PM
jeropon
11-06-2013 07:09 PM
jagstein
11-12-2012 04:50 PM
hdfx81
09-29-2011 06:36 AM
Mike2288
05-06-2009 01:47 PM
Quick Reply: Newbie to Jag 99 xj VX vanden plas.. need advice
Advertising
Featured Sponsors
Vendor Directory
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
