XJS HE V12 Exhaust
Received 10,741 Likes
Tons of archived discussion on this.
The Jag V12 can take on a rather odd exhaust note with low restriction mufflers....but an X-pipe or H-pipe added into the system yields a very pleasant tone.
On my present V12 I went with four glass packs and an X-Pipe. Happy with results.
Others will chime in.
any chance of adding a quick video or sound bite? Would love to hear your setup?
I have a temporary system - gutted cats, high-flow glasspacks (don't like) leading to side exits ahead of the rear radius track arms.
The sound at idle or barely touching the gas is quite nice if you like deep V8 type sound, everything from that to 3000rpm is terrible, and everything after 3000rpm sounds a lot like this
It is also great for growling at people by backing off the pedal while still giving it some gas.
I'd suggest getting (new) replacement UK version downpipes which will delete the CATS, delete all the center mufflers add an X-pipe and retain the stock rear resonators under the trunk, but open up the exits if you can. I believe the race cars often had dual exhaust tips on either side. Your car will feel brand new once it can breath properly without all those god forsaken mufflers and clogged cats on there.
The following 2 users liked this post by Segfault:
89 Jacobra (07-15-2018),
Doug (07-15-2018)
For those who want to know what they are doing: Exhaust Theory
Ahhh. Very good. Interesting and informative. But who of us has the knowledge and ability to, let's say, measure and analyze the reversion effect, or the compound energy waves that occur during exhaust scavenging? And then determine what is most ideal for the Jag V12 engine and, from that, engineer a system for optimal results within xxx-rpm range?
What most of us are after, simply, is a pleasant and sporty tone from the exhaust and, given the costs of custom exhaust work, I suspect few of us have the resources (or willingness!) for unlimited experimentation.
The following 3 users liked this post by Doug:
Received 1,231 Likes
most here have seen my side pipe,, ALL 12 cylinders into 1 large 5" outlet 2 glass pcks!
the sound around 3500 up is amazing+ loud, and back off is a some snapin,poppin, at 6000rpm it almost becomes a whistlin sound, the exhaust pulses start to blend into one sound(ears cant seprate the pulses).
not for everyone , but my car is not built for everyone!,, and idling is great, most motorheads give it thumbs up!
about 1/2 hour, it really makes one AWARE of the right&left sides tho,, 25yrs and counting NO fails. i can pullup in traffic stops and shake hands with other driver,,LOL.
89 Jacobra (07-16-2018)
The following 2 users liked this post by fat_cat:
89 Jacobra (08-03-2018),
ronbros (08-03-2018)
Hi all,
Ok, here is a comparison video of the standard exhaust vs the new single dual in, dual out Magnaflow 11386!
Headphones be best
I have also added to 20 inch glass packs after the rear wheel . (Video posted of this soon)
Factory Exhaust
Magnaflow 11386
Headphones be best
Factory Exhaust
Magnaflow 11386
ronbros (08-10-2018)
