Jaguar Forums - Jaguar Enthusiasts Forum (https://www.jaguarforums.com/forum/)
-   XJS ( X27 ) (https://www.jaguarforums.com/forum/xjs-x27-32/)
-   -   radius arm problems (https://www.jaguarforums.com/forum/xjs-x27-32/radius-arm-problems-233968/)
rgp Jun 16, 2020 03:30 AM
radius arm problems
Just refitted and bolted up the rear subframe and the radius arms are about an inch out when trying to fit. what have I done wrong any suggestions to fix the problem please,
https://cimg0.ibsrv.net/gimg/www.jag...2c77428383.jpg
Grant Francis Jun 16, 2020 04:48 AM
Been there.
Loosen the 8 "V" mount long bolt/nuts.
Place a bottle jack under the large bush, block of wood for protection of course, and jack them onto the posts. The will sit there when the jack is lowered, so the bolt can be installed.
Dont jack ON the arm, they will bend.
Tighten those 8 bolts when you are done.
rgp Jun 16, 2020 05:54 AM
fixed....it was because I had tightened the four mounting nuts while it was jacked on the diff, so I undid the 4 mount nuts, put the axle stands back under the the body
lowered the jack and jacked the front of the subframe under the diff, and it all lined up, had me worried for a bit,,
Grant Francis Jun 16, 2020 06:54 AM
BEER O'CLOCK then, good stuff.
© 2026 MH Sub I, LLC dba Internet Brands
