Rear anti roll bar
With regard to the rear anti roll bar would anyone know if replacement drop link bushes are available as opposed to replacing the whole thing.? I have looked for polybushes and can’t find a replacement, is it possible to make your own? Or does anyone know of uk suppliers. Don’t really want to buy new from jaguar at 55 pounds plus vat and postage each side or cheapo that won’t last 2 minutes. Any help with suppliers etc gratefully received. All uk based ideally. Many thanks
You can replace the whole drop link with adjustable heim joints .
Manners and John Gordon's stuff is usually pretty good Brinny. Try these:
Manners 31 quid http://www.jagspares.co.uk/Manners/p...rtno=C42907%2A or the 35 quid opiion https://www.ebay.co.uk/itm/JAGUAR-RE...-/121034862242 Greg |
The part number is C10940
I replaced them and I'm pretty sure I was able to buy new from Jaguar....but without checking my notes I'm not 100% certain. Cheers DD |
For poly bushings....
https://www.terrysjag.com/product/C10940TJP.html The drop links are the same use on the XKEs. That opens up more searching possibilities Cheers DD |
C10940 has been used on lots of cars over the years. If you want poly bushes, talk to Rob Beere in Coventry, I believe they have them.
Originally Posted by Doug
(Post 1832641)
I replaced them and I'm pretty sure I was able to buy new from Jaguar....but without checking my notes I'm not 100% certain. DD I have part number C42907 from my searches. These are available from Jaguar but as huge cost as the OP mentioned. My links are this same part number but miles cheaper. Your number is listed by JCP as a front ARB drop link for the Daimler limo. https://www.jaguarclassicparts.com/uk/part/C10940 Greg |
(Post 1832701)
Your number is listed by JCP as a front ARB drop link for the Daimler limo. |
Right, C10940 is the bushing, #26 in this illustration but used on many models besides the limo
https://www.jaguarclassicparts.com/u...ember-assembly C42907 is the entire link, #6 in this illustration https://www.jaguarclassicparts.com/u...tre-sportspack Cheers DD |
(Post 1832719)
https://www.jaguarclassicparts.com/u...ember-assembly C42907 is the entire link, #6 in this illustration Cheers DD Greg |
(Post 1832759)
Thanks Doug. So if the Op has the metal bit already, all he needs to do is buy the rubber, which is cheap.
Greg Removing the old ones is what takes the time :) Cheers DD |
That’s a big help thank you all.
