Rear Clunking source found
Looks like this seal is perished- multiple times- no wonder I hear a loud clunk going over pot holes. I will certainly be replacing both sides, but if there is an obvious other bushing I should refresh when this gets done, please let me know
https://cimg0.ibsrv.net/gimg/www.jag...3261a3c40.jpeg |
The small bushes at the front of that arm will be simple when its off for that large refurbish.
Mark,
From that photo, your radius arm looks in pretty good condition as regards corrosion. However, if it's not perfect, it's often more cost effective to buy a new arm complete with bushes fitted, rather than having new bushes fitted to your original arm. Search around for prices. If you do just change the bush, you might want to consider tightening up the ride a bit by installing the bush at 90 degrees to the original fitment. In other words, with the air gaps in the bush to the sides, rather than front to back. This tightens the axle movement a bit and was the way they were fitted to XJR-S cars. Cheers Paul |
Originally Posted by Spikepaga
(Post 2072251)
https://cimg0.ibsrv.net/gimg/www.jag...3261a3c40.jpeg https://cimg5.ibsrv.net/gimg/www.jag...10b9820bb3.jpg |
Originally Posted by ptjs1
(Post 2072431)
Mark,
Originally Posted by carsnplanes
(Post 2072509)
I find it interesting that the bracket that is supposed to hold the bushing bolt steady or aligned properly is not in line with the expected movement of the radius arm. Since the job of the radius arm is to set a distance for the hub to remain, any movement would be in the fore and aft direction. This would try to move the securing bolt and bushing in a fore and aft movement but the securing bracket to oppose that is on an angle of that direction rather than in the same direction, so there would still be movement. Why was the holding bracket installed this way?
https://cimg5.ibsrv.net/gimg/www.jag...10b9820bb3.jpg Is this an eccentricity that pertains to my car only, or do all the cars that bushing installed like this from the factory?. I am going to ask my mechanic to press the new ones in as Paul indicates |
The task of that bracket is to retain the arm in place, sort of, in the event of total failure of the large bush. It is a SAFETY bracket, nothing to do with what the arm does, never was intended as such. That bush sits over a pod style thingy attached to car frame.
Apparently some markets reported that bush failing completely, and the arm dropping down and hitting the tarmac with the usual resulted damage, as in OOPS. This was waaaaaaay before the XJS was twinkle in the Jaguar eye. My 1965 S Type had them, the 1963 MK10 did not. My take was that the "mechanic/caretaker", servicing the car, and dutifully greasing all points as Jaguar required, failed to notice perished bushes, so the bracket appeared to cover "stupids" backside, MY OPINION, and the word at the Dealer back on my time. |
Solved. Clunking completely gone. This was exclusively a transmission mount issue.
