Smell of fuel in the boot
Evening all, I had the fuel tank re sealed and repaired at Xmas. I have re connected everything a couple of months ago and am sure there are no leaks. Despite this I am still getting a smell of fuel in the boot. Any suggestions to possible problems or solutions please. Many thanks in advance.
In my case the smell came from leaking steel line over the IRS
Those pipes are new as well. It seems to be coming from the filler cap area.
How is your pressure at the fuel cap after a drive?
Have you checked the vents, they are on the RH side of the tank at the top.
Mine got some gas into the foam backing of the rubber mats. I washed them but still the odor is there although not nearly as bad as it was.
I probably should have replaced the mats when I replaced the gas tank two years ago. |
Originally Posted by Time-Pilot
(Post 2067077)
I haven’t driven the car. It has been on axle stands for some time undergoing restoration work. |
Originally Posted by warrjon
(Post 2067102)
Evap system always comes to mind, but not sure if you have one.
I don’t think I have. It’s an 89 v12 convertible. Tank is slightly different to a coupe I think?
If the sender unit was removed, it is possible the gasket was not replaced or is too old.
Brinny
Which of the many pipes inside the boot did you renew, as well as sorting the tank? Just a few ideas: It would be worth taking a very careful look at the filler flexible. This is not easy to connect properly and tighten Did you use new olives on the connectors into the boot? If all else fails, then block the inlet and outlet pipes and all the others except one, and pressurise the tank using a radiator pressurising gizmo from some pipe or other and see where it weeps/hisses etc. |
brinny,
You didn't mention which of your cars is having the problem? IIRC, the 4 litre facelift setup has 3 flexible hoses on the top of the tank. The one that is the most inaccessible has a tendency to collapse and deteriorate which can cause fumes in the boot. Good luck Paul |
Lots of possible sources for the smell as indicated by the various responses. I'd invest in a fuel sniffer like the Tif 8800 to help isolate the source. Very useful and time-saving tool and you can get them used off of ebay for $50-$80. I used one on my XJS to trace the fuel odor source to a wiring bodge through the evaporative flange on top of the tank. Good luck.
also , i have had many different makes of cars,, and ALL of those with the tank located INSIDE the car body always had some fuel oder! (of course there are exceptions)
the cars with tank and associated parts located outside the body, had little to nothing for oder!,,(altho they had other problems,like crash fires,minor stuff tho LOL. ron |
brinny,
apols, just noticed that you were talking about your 89 convertible. Paul |
Thanks for all the replies, I will dig deeper. All hoses were renewed when the tank was replaced and I will indeed check the filler hose connection Greg. I feel it is in that area my problem lies. Once more thanks lads.
I suggest taking the tank out. the car s 30 years old. If it ever had moisture in the trunk (boot) and it got under the tank it could deteriorate it over time.
All kinds of hoses and connectors associated with these cars. Two additional potential sources are the fuel sender unit locking ring not being fully seated and the fuel filter clamps. Also check the 'expansion tank' and hoses located under the battery on my '87 |
In my case, I was getting seepage from the sending unit. Not the gasket and locking ring, but the actual sending unit.,
There is a "gator" right at the top of the filler neck. It is fragile (mine was after years of sitting) and I would imagine that part of resealing the tank would very well have disturbed the gator, fuel cap, fuel tank connection... It is ribbed/accordion style and a leak in this is not always easy to see. Ya can't get your eyes around the entire circumference to check.
What might help checking is to undo the bolts/screws that hold the gas cap to the body, undo the clamp (in the boot) that secures the gator to the cap assembly, remove the cap and then inspect the gator cap assembly seal from outside the car/boot.... Just my 2cents... |
