Wheel bearing races
Old Apr 11, 2024 | 08:37 PM
MrAndersonGCC's Avatar
Default Wheel bearing races
Two questions:
1. Any tips on knocking out the races? I located the indents in the hub and still struggling to knock them out.
2. How critical is it to replace the races themselves? Obviously the bearings are a wear item but the races look fine to my eyes.
Old Apr 12, 2024 | 02:47 AM
Greg in France's Avatar
use a drift and knock out the races by hammering the drift down the indents a little bit each side. You need to hit it hard!
Very important!
Old Apr 12, 2024 | 07:42 AM
Doug's Avatar
Originally Posted by MrAndersonGCC
Two questions:
As Greg says
Traditionally the recommendation has always been to replace the races when replacing the bearings because the races will have some wear....even if minute....which prevent perfect bearing-to-race contact.
I suspect what's likely to happen if you don't replace them would be the new bearings simply not lasting as long as they should.
But....
Just replace 'em. You'll feel better in the end!
Old Apr 12, 2024 | 07:22 PM
Appreciate the replies gentlemen, but I give up.
I have hit the backside of the outer race countless times, hard, and it hasn’t moved a hair. And yes- I’m hitting it the correct direction where the two little indents are.
jmeiners
Jun 11, 2023 08:56 AM
wierciu
Sep 8, 2019 10:57 PM
Johnken
Jun 9, 2017 03:43 AM
2meke
Jul 2, 2013 03:36 PM
tenativelyproud
Mar 20, 2013 03:29 PM
