Where does this belong
While having a rummage today in the engine bay, I came across this loose connector.
It has the look of an injector connector but it was down by the alternator, just sitting about. All ideas are welcome, thank you. Ps, it is in/comes from the light coloured wiring loom Graeme https://cimg0.ibsrv.net/gimg/www.jag...0ab220f4ce.jpg |
On my '90, there are 2 of those plugs right front corner of the motor. One is a coolant temp sender behind the right thermostat and the other is on a vacuum valve that is in the air injection pump circuit. The coolant one on mine is black and the vacuum one is blue. Good luck!
Thanks Jerry, I will have a look.
